E90 330i automat 2005 jag vill byta batteri måste den programeras?
Sida 2 av 2
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Titansilber Metallic
Man programmerar med Tool32 eller NCS som också är med i paketet.
Jag har faktiskt aldrig gjort det så jag vet inte exakt hur.
Men det går nog att ta reda på!
Mvh Ola
Min bil:
ex
231
extravagant77
325i Touring E91 2006
Tack för svaret!
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Det gick fort att hitta!
I andra delen av guiden registrerar de med tool32 vilket går bra men det är lättare med Inpa.
Mvh Ola
Min bil:
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Hitta detta i en tråd också:
Hela tråden: Länk
Urklipp:
The cars FRM/CAS/LMA module needs to be reprogrammed VIA NCS EXPERT.
I do not take any liability if you do not know what you are doing.
Here is a VO order for battery sizes.
-B080 80 Ah Battery
-B090 90 Ah Battery
-B110 110 Ah Battery
-A080 80 Ah AGM Battery
-A090 90 Ah AGM Battery
E90 has FRM module but same way of coding it.
Its not necessary to code all car after FA changing but cas and lma (in e60), frm (e90,e70) must be coded.
Changing battery size:
1. Open NCSEXPERT
2. File > Load profile > Select Expertmode > Click OK
3. Press F1 (VIN/ZCS/FA)
4. Press F3 (CS/FA f. EC) > Select E60 > Click OK > Select CAS > Click OK
5. Press F6 (Back)
6. Press F1 (VIN/ZCS/FA)
7. Press F2 (Enter FA) > Select E60 > Click OK
8. A window labeled “Eneter VIN” appears with your vehicles VIN number filled in > Click OK
9. A window labeled Enter FA appears > scroll to find VO for old battery (-B090) > highlight –B090 and press delete on keyboard
10. Enter –A080 is “Attribute” box > Click Add > Click OK
11. Press F6 (Back)
12. Press F4 (Process ECU) > Select CAS > Click OK
13. Press F2 (Change Job) > Select FA_Write > Click OK
14. Press F3 (Execute Job)
15. Verify that the write is complete “Job Ended”
16. Press F1 (Change ECU) > Select FRM > Click OK
17. Verify lines : get coded, FRM, JOBNAME = FA_Write
18. Press F3 (Execute Job)
19. Verify that the write is complete “Job Ended”
20. Press F6 (Back) > Exit NCSEXPERT
ex
231
extravagant77
olaO. Har mailat dig via Blocket.
