Bilstereo Navi Tele Ljud Larm
2.669
Årgång och utgåva på naviskiva
Sida 2 av 2
pu
528
pulare
520 D F11 2014
If you have 4-1/70 or higher then you can have 3D perspectibe mode, to enable this, Perspective mode needs to be enabled in 2 places,
1: The hidden setup menu.
Go to the menu screen select set (or settings) and hold menu button for 10 seconds, when the hidden menu appears scroll down untill the perspective mode option is selectable.
2: In the arrow map pointing menu.
Select GPS-Navigation, then Map, then push right button, select Map Positioning and there select Perspective
RizztO
BMW 540IA M-Sport -03 Svart som döden
Dodge 4x4 w200 -77
BMW 635CSI -79 Svart
Opel Kadett super -69 Ferarri röd
Tack pularen! Nu blev de 3D =)
Real x-traktor power =)
