Oljeförbukning e39 (den slutliga tråden)
Sida 2 av 2
Länken funkade inge vidare så jag klistrar in istället:
SPECIFIC LL-04 5W40
Gasoline and Diesel oil for EURO IV engines
100% Synthetic
TYPE OF USE
Specifically designed for BMW and MINI (gasoline) cars fitted with EURO IV engines (M43CNG, M47/TU2, M57TU, M57TOP, M57TU2, M67TU…) that require "low SAPS" lubricants : low Sulphated Ashes (<0.8%), low Phosphorus and (< 0.08%) low Sulphur (< 0.2%).
Specific LL-04 is recommended in European Union countries, Switzerland, Norway and Liechtenstein. In those countries, Specific LL-04 can be used where BMW LL-01, LL-01 FE or LL-98 is required except for M3, M5 and MINI Diesel, refer to BMW recommendation.
PERFORMANCES
STANDARDS ACEA A3 / B4 / C3 - API SL / CF
APPROVALS BMW Long Life-04
Level of performance BMW Long Life 01'
Engines compliant with EURO IV anti pollution regulation are fitted with sensitive systems for exhaust gas post treatment :
- Sulphur and Phosphorus inhibit catalytic convertors operation and can damage catalytic components : inefficient exhaust gas treatment.
- Sulphated Ashes clog diesel particulate filters : shorten regenerating cycle, higher fuel consumption and engine power loss.
BMW developed BMW LL-04 standard for low SAPS lubricants (low Sulphur, Phosphorus and Sulphated Ashes) compatible with post treatment systems. Those oils allow reaching extended drain intervals managed by computer on board.
ATTENTION : BMW LL-01, LL-01 FE and LL-98 lubricants must not be used where BMW LL-04 is required. Use BMW LL-01, LL-01 FE and LL-98 lubricants would damage post treatment system.
christer silvén
330E -20 G20
520D -17 G30
420D cab -17 F33
Jo, det är den oljan jag använder, och ingen oljeförbrukning trots att bilen gått snart 30000 mil.
BMW CS #5206
He
3.464
Hewi
530iM-00 Immolarot II
118D-08 Karmosinröd
Om man inte har någon olje förbrukning kanske det beror på att oljan ligger kvar i oljetråget? skämt och sido alla motorer drar lite olja annars är något fel! Men normalt sett så klarar man sig utan att fylla i olja mellan service tillfällena.
