890
SMT6 or MS+EDIS6
Ki
64
Killerbee
338i - 94
Sorry for Engilish but please post me your suggestion what to go for ... SMT6 or Megasquirt + EDIS6
It is for turbo S38B38 not much power - about 450-500 flywheel hp
If you not want to write much please post only SMT or MS
megasquirt of course its a standalone system. Smt is best for piggyback or extra fueling.
Ki
64
Killerbee
338i - 94
Main problem with MS is that I can not find any base map and no one can make me ( from people I ask )
The thing with systems using VE table is that you input som engine data and calculate a req fuel figure. I usually just type in about 70% VE in the whole table and then start the engine. Once you got i started it´s really easy to tune.
Ki
64
Killerbee
338i - 94
Thanks Bäckis that will help me a lot . What about the ignition maps - can someone give me an map which will help me to start an S38B38 - than I will map by myself
I can surely provide with an ignition map to start the engine. When you´re so far on with the installation of your MS system that it´s time to turn the key, just send me an email and I will give something to start with.
Ki
64
Killerbee
338i - 94
Thanks
So I continue with turbo instalation , go for MS + EDIS6 - it will be more safe to run stand alone EMS than piggyback
