Färg på M5-paket
Behöver hjälp med vilket nr, silverfärgen på M-paketet har tillsammans med Daytonaviolett?
Tack på förhand..
Micke.
HD
1.579
HD91
E61 523i touring
E61 530d touring
237 Granitsilber-metallic.
- M5 E34 Limousine register -
Tack för den...
Jocke W
M5-89 E34
750iA-96 E38
750iA-05 E65
X5 3.0-06 E53
318i-92 Cab E30
Z3 Roadster 1.8-96
På 3.6:an skall det vara "Sebringgrau nr229" enligt BMW.
3.8:an har en ljusare kulör...
Mvh Jocke W
Jocke W
M5-89 E34
750iA-96 E38
750iA-05 E65
X5 3.0-06 E53
318i-92 Cab E30
Z3 Roadster 1.8-96
Var lite snabb där... inte alla(senare) 3.6:or har nr229
Info ifrån M GMBH:
I hv now received an answer from the M-GmbH to my inquiry and unless proofed otherwise we have to assume this to be correct in general -
contrast-colors used for the E34 M5-skirting/aerodynamic package = Sebringgrau, metallic (229) - up to 1991 = Granitsilber, metallic (237 M) - from 1991 = Diamantschwarz, metallic (181 M) - all models
the change from Sebringgrau, met. to Granitsilber, met. was made in 1991 (most likely at model-year-change from '91 to '92-model, not confirmed) also it was not specifically confirmed which color was used on the '93 US-model (3.6 Li S38B36), HD 93, 12/89 - 03/93 -
to make the issue even more tricky BMW at the time offered an option (against additional payment) to have the skirting/aerodynamic package painted in the colour of the car
OR IN A DIFFERENT CONTRAST-COLOUR AT BUYER'S CHOICE -
although there are a few cars known and confirmed without a contrast-color it is not very likely that there are many cars out there with a different contrast color -
car owner's with an unidentified (490 U - Sonderlackierung) special-paint car and/or in doubt about the -contrast-skirting-color should ask their BMW-contact to obtain confirmation from the M-GmbH via the VIN-ref of the specific car
Mvh Jocke W
HD
1.579
HD91
E61 523i touring
E61 530d touring
3,6:or lackerades inte (förutom någon enstaka "Serienvorläufer" möjligen) i daytonaviolett-metallic, därför blir svaret 237 Granitsilber, ty kulören är 3,8 specifik.
Det råder vissa oklarheter kring skiftet 91 och 92, som jag tolkar det från prospektet så gäller 237 fr.o.m 1992 års M5 3,8 och M5 touring endast, 3,6:or (europeiska bilar i varje fall) borde inte ha omfattats av den ändringen utan fortsatt i sin normala kulör till produktionsstopp.
3,8 började tillverkades redan 91 men som 92 års modell så det är säkert därför BMW anger skiftet 91/92.
Prospektet, troligen det sista för 3,6, tryckt i mitten av 91, anger fortfarande 229 Sebringgrau som kontrastfärg. Besvärligt ämne som sagt, jag tror inte ens BMW själva har full koll?
Nej,, BMW har inte full koll!
Det var därför jag frågade här ;)
m5
976
m5toureg
E34 M5touring '95
E9 CS-A '75
AUDI A6 Avant 2.4 Quattro
B10Alpina@ jo då de har visst koll MEN det finns en massa folk
som jobbar där som inte byr sig.........kontakta ///M-GmbH
direkt så får du svar, å andra sidan finns det ju (normalt) inte så mycket att välja på. så din BMW-handlare kan ju ta en -touch-up-set-/lackstift- och jämföra med din bil - så är problemet löst,
lite fantasy bör man väl ha, först när de två alternativen inte
matcha är det dags att kontakta ///M för att vara säkert, som
du säkert förstå förutsätter det att bilen INTE har blivit omlackat
tidigare, ///M har så klart bara uppgifter på HUR bilen var när den
lämnade dem 'heliga hallarna' i Garching -
Jocke W@ wow, den texten verkar bekant, jag undrar vem som
kan har skrivit den ?;) (ibland kan det vara skoj att få lite
erkännande för mödan ;) MEN helt 'ok' Jocke 'no problem !!;);)
Jocke W
M5-89 E34
750iA-96 E38
750iA-05 E65
X5 3.0-06 E53
318i-92 Cab E30
Z3 Roadster 1.8-96
m5toureg: :-) "cut and paste from Länk
Tack för lånet.
Mvh Jocke W
