Bilstereo Navi Tele Ljud Larm
1.173
@ HIDDEN NAVI HACKS @
nsumar
Hidden HACKS
Ni som har Tips om dålda Menyer och Funktioner för NAVI kan ni inte posta den under detta inlägg, vore bra om man fick dessa under en tråd.
Eliminating the Navigation Accept Screen
On the BMW MkIII and MKIV navigation systems, if you downgrade to an older software version and then reinstall a newer software version (such as going from V23 down to V22.1 and then back to V23) , the navigation system may reset out of USA mode and put you into UK mode which results in the elimination of the "Accept" screen from your system.
You will know this has happened if (1) you are receiving directions from your system in yards instead of feet and (2) the "Emergency" option has disappeared from your main menu.
To reverse this, the dealer must hook the vehicle up to their computer and recode the navigation system to "USA" mode.
There is also a module that has been developed and is being sold which intercepts the i-bus command and will send the "Accept" command to you on your behalf. For more details on this solution, see the web site Länk
how to access hidden info on CD-based GPS system
Select SET screen, then hold down MENU button for 8 seconds. A new menu screen will appear, allowing you to read out information on GPS nav system, including satellite strength, heading, altitude, ground speed, etc.
Navigation_Software_Updates
BMW_NaviSoft_KeyCD_
