1.290
Kan detta styrsystemet vara nått?
Tu
150
Turbokåt
3231 (e26) -96
M535 (e28) -87
528i (e28) -85
528i (e28) -83
518i (e28) -83
Det här ska tydligen vara ett sjyst styrsystem som ska vara hyffsat billigt... Länk
Vad tror ni här om det???
Nån som känner för å mejla å fråga priser?? Jag är inte så han på det där med engelska...
///Jimmy "Kjelle" Larsson
PM Racing
klistrade in prislistan nedan
//M
SDS Retail Price List (U.S. Dollars)
Effective Oct. 15/03
EM-4D EM-4E/MSD*
triggers Multispark EM-4F
Basic EFI Kit 4 cyl. $841 $1007 $1249**
Basic EFI Kit 6 cyl. $874 $1056* $1414
Basic EFI Kit 8 cyl. $927 $1136* N/A
Mazda (2 rotor) $841 N/A N/A
*EM-4E without ignition coil, coil driver, coil bracket. You must have one of the popular ignition boxes, such as MSD, Crane etc.and a coil.
S.D.S. controls igniton timing by triggering the points wire.
**EM-4 4F version is available without coils. Intended to drive OE coil packs. Price $1179US.
EM-4 4F version is also available to drive MSD DIS-2 box. DIS-2 not included. Price $1093US.
With Optional Knock Sensing (E & F systems only) $91
Optional Fuel Pump Relay $30
Optional Fast Idle $75
Optional RPM Switch Control $30
Optional Electric Fan Control $30
Optional Supercharger Clutch Control Toyota 4AGZ $30
MAP Sensor 1 Bar Abs(for normally aspirated) $64
MAP Sensor 2 Bar Abs(up to 15 psi boost) $75
MAP Sensor 3 Bar Abs(up to 30 psi boost) $90
TPS Kit 5/16 D Shaft Drive (specify CW or CCW TPS end shaft rotation) photo $68
Optional Dale 1/8 NPT Temp Sensors $10
Optional Bosch 12X1.5mm Temp Sensors $18
Optional Bosch CHT Temp Sensor for Air Cooled Engines N/C
Mixture Meter without Sensor photo $78
Mixture Meter with Unheated Sensor and Boss $126
Mixture Meter with Heated Sensor and Boss $142
Large Bosch Pump to 600 hp photo $279
Small Bosch Pump to 300 hp photo $225
Bosch 13 Ohm Injectors, 300cc, Domestic O-rings, disc photo $60
Bosch 13 Ohm Injectors, 420cc, Domestic O-rings, disc photo $75
Siemens 2.5 Ohm Injectors, 570cc, Domestic O-rings $85
For Bosch and MSD high flow injectors, contact PTR injection: www.ptrsds.com
Extra Injector Controller, includes injector harness $349
2 injector kit with bosses, clamps and hoses $171
4 injector kit with bosses, clamps and hoses $343
Aluminum injector boss. For use with EIC injector or fuel rail hold down Photo $17
Steel injector boss. For use with EIC injector or fuel rail hold downPhoto $19
Unheated, 1 wire O2 sensor $43
Heated, 4 wire O2 sensor $64
Backlit LCD programmer option. Add backlit display only. Not complete programmer. $50
Custom wiring harness lengths $30
Other separate and replacement part prices can be found by going to the online ordering page price lists, below
Please note that basic kit prices do not include fuel hardware such as injectors, pumps, regulators etc.
We do not recommend fuel pressures exceeding 60 psi with our injectors. Injectors carry no manufacturer's warranty.
All prices in U.S. dollars. Canadian prices available by clicking on the online ordering links
"Man skall sikta mot stjärnorna, då når man iallafall trädtopparna"
andra bilar:Saab900T16@TD04
ch
309
chrcel
m3coupe-96
nån som vet mer om det här???
mvh pezen
varför finns det inte powerflex till e34=((
ek
885
ekblom
BMW M5 E39 -02
BMW 530xd T -07
BMW 120iA -07
räkna ihop allt du behöver, jämför sedan summan med ett autronic för 17-18k nytt..
TwinTurbo=Twice the fun :D
ek
885
ekblom
BMW M5 E39 -02
BMW 530xd T -07
BMW 120iA -07
räkna även in frakten och tull/skatt från USA
