Bilstereo Navi Tele Ljud Larm
1.575
E60 stereo info
HFR
E92 M3 DKG
E46 330iM
hej
söker info angående ljudanläggningen i E60.
vad är "setup'en" när det gäller högtalare? har hört någon tala om 6"midbasar under framsätena..kan det stämma?
ger cd'n balanserad signal ut? via fiberoptik?
någon som vet?
mvh
or
725
oreo
323i -85
Den bästa informationen jag lyckats hitta kring vilka högtalare som ingår i respektive anläggning är i detta:
När det gäller utsignaler mm vet jag inte.
//Örjan C
HFR
E92 M3 DKG
E46 330iM
tack för ditt svar!
kommer du ihåg vad det stod?, för jag får upp "websida okänd" på del 4-8.
mvh
or
725
oreo
323i -85
Här är ett urklipp av informationen i In depth dokumentet:
"A unique sound experience on four wheels:
The audio systems in the new 5 Series
The new 5 Series Saloon comes as standard with a high-quality, sophisticated stereo system featuring the BMW Business radio and a CD player. Other HiFi systems ensuring the highest standard of audio quality are also available as an option. The Professional radio also comes with a player able to provide not only the standard CD functions, but also CD-ROM functions, thus playing back data files such as MP3 CDs. This radio system is once again part of the navigation unit.
A special satellite radio is available in the USA for the satellite broadcasting system with virtually nationwide coverage.
Optional: CD and DVD changer
As an option, the audio systems may be supplemented by a CD changer within easy reach of the driver and front passenger: The main unit is integrated in the interior of the car and is hidden in the glove compartment. The changer is operated via the Controller and Control Display, operates particularly smoothly and quietly, and can accommodate up to six music CDs. A multimedia changer is also available either as an additional or as an alternative feature. Likewise operated via the Controller, this multimedia changer is able to accommodate six CDs, audio or video DVDs and is fitted in the luggage compartment behind a flap in the left-hand wheel arch section.
HiFi system with two central bass loudspeakers
Two central bass loudspeakers beneath the front seats providing perfect reproduction of low sounds throughout the car form the very “heart” of the HiFi system. As in the 7 Series, the volume required is provided by linking the central bass loudspeakers to the side-sills. A tweeter is housed in each of the mirror triangles, and a sub-woofer is integrated in each of the front door panels. Two further sub-woofers are integrated in the parcel shelf, with two tweeters in between.
The top HiFi concept: BMW’s Professional LOGIC7 system
The Professional LOGIC7 HiFi system offers the driver and passengers in the new BMW 5 Series high-end audio quality with supreme technology carried over from the BMW 7 Series: As the world’s first system of its kind in a car, this HiFi technology applies the LOGIC7 concept so far only to be found in stationary professional and semi-professional sound systems. LOGIC7 is a special digital audio signal processing mode for two-channel stereo signals and multi-channel multimedia signals.
The objective of LOGIC7 is to create an experience in sound as true to the original as possible for all listeners within the car. To do this, a matrix circuit splits up every signal of an analogue or digital stereo recording into seven individual signals then processed specifically in accordance with the car’s interior configuration. To provide a multi-dimensional sound experience as close to the original as possible, LOGIC7 uses the spatial information contained in each stereo signal and breaks down this information into the two crucial sound dimensions: The place where the sound was originally generated and the acoustic environment or the location where the sound is now disseminated.
This gives the listener an even greater experience in spatial sound and more precise resolution, allowing him to locate individual sound sources with even greater precision. Particularly moving sound sources such as a car passing by are presented far more plastically and impressively.
The Professional LOGIC7 HiFi loudspeaker system comprises the following units:
Four tweeters in the mirror triangles and in the parcel shelf
A 100-millimetres conical sub-woofer serving as the central loudspeaker in the middle of the instrument cluster
Four 100-millimetres conical sub-woofers in the doors and three in the parcel shelf
Two 210-millimetres central base loudspeakers beneath the front seats.
Individual entertainment for the passengers at the rear
The rear seat passengers benefit from two supplementary systems allowing them to put together their own entertainment programme: First, the “basic” rear-seat entertainment system offers the passengers at the rear the opportunity to listen to music, etc over headphones, with two headphone sockets fitted in the centre console. The entertainment menu itself is operated by wireless remote control: Once you press the menu button, a pop-up window appears in the Control Display in the cockpit, which may also be read from the rear. The usual menu finder in the basic menu is replaced in this case by a headset symbol, the user then being able to move around within the menu by remote control operating the same way as the Controller – by pushing, pressing and turning the button. Both a directional control block and a push/press button are provided on the remote control for this purpose. Commands entered on the front Controller nevertheless have priority over this system in all cases.
The basic principle is that internal sound sources such as the radio or CD player can be specified and pre-set only once: If the driver is listening to the radio the passengers at the rear can only listen to the station the driver has selected, but they are able at the rear to listen to, say, a CD over the headsets."
//Örjan C
HFR
E92 M3 DKG
E46 330iM
tackar,
undra va de menar med: "linking the central bass loudspeakers to the side-sills"..? har då inte sett ngt sådant på nya femman..
positivt att man får in 8"are under sätet dock..
