HOW WIDE ARE MY ORIGINAL ALU WHEELS E34 535
iv
77
ivenos
535i -88 BSR trim
Anyone who knows how wide are my original 15" criscrosed wheels on my e34 535 from '88 .
Is it 7" or 7,5"
Can i have 185/65/15 winterwheels on? or i need to have 195/65/15 and higher?
Thanks
th
1.421
theprophet
Alpina 530iT "B3" -94
i belive it should be 7,5"
And if i were u i'd go with 195 atleast! 185:s Weight index is rather low for that car!
__
there should be a mark on your wheels for example 7Jx15. The number before J tells you how wide the wheel are in Inch, the number after the x is telling you the wheels size in Inch.
search for that number/letter combination and you will find it out
"Även en 316 kan man ha kul med vintertid"
li
1.959
liste
535i -89
You need to go with 195/65-15's.
ErikW
E28 520i - 85
E32 750iLA - 89
E92 325iA Coupé - 08
F11 530i Touring - 12
Originally 535i had 225/60-15 on those rims, 7x15. You can use 195/65-15, but I suggest you use 205/65-15 because of your car's weight. Avoid 185/65-15, they are too narrow and the load index is to low.
Erik
Trender är bara för amatörer, vi andra går på instinkt!
iv
77
ivenos
535i -88 BSR trim
thanks everybody!!!!
