Försäkring och Värdering
575
318is e30
iv
77
ivenos
535i -88 BSR trim
I am lanning to buy a 318is -90 e30.
Some tips about things that i should have my mind on while inspecting it?
Any consisting faults on this spesific model?
Any help is wellcome :o)
no
3.595
nofx16
BMWCS[syd]#5120
Hi!
If you can read and understand swedish, you could begin with reading this 60 page-long thread: Länk
If not, I will try to translate some of the most important parts of it to you.
Also be sure to check out: Länk
Br,
Kalle
iv
77
ivenos
535i -88 BSR trim
I unfortunately do not understand many of those writen in this link.
I would apreciate if you could tell me some general and most important and expensive things i should check.
Haglund2306
316i Compact -97
Like all other E30:s; RUST! If you can find an E30 without rust between the windshield and the hood and on the inside of the back-hood (right?) then you've probably found quite a piece of E30.
The engine seems to be very reliable and so are most of the other mechanic stuff such as gearbox, differential and others.
The M42 engine is a bit cranky about getting the right oil though. Make sure the car has been properly served with the right oils, filters and more within the right time and mileage.
Bitte benutzen Sie die Suchfunktion.
no
3.595
nofx16
BMWCS[syd]#5120
There are generally not so many specific problems with the 318is -90. One of the most important things to investigate is the amount of corrosion. Try to get a look from under the car.
Try to make some fast gear-changes. There shouldn’t be too much resistance between the gears, or any strange sounds from the transmission.
Drive the car on some road-bumbs or on a bad road. Does the suspension feel or sound strange?
How does the engine sound? Does it rev smoothly all the way to redline? (Only try this when the oil has reached its working temperature).
Check the color and quality of the oil.
For better information in English maybe you should try an English-speaking forum, such as Länk
Mvh,
Kalle
____
Min 320iK: Länk
