FRONT POSITION LAMPS
iv
77
ivenos
535i -88 BSR trim
Anyone who knows the code name of the front position laps used on E34 models? is it W4W?
MW
517
MW-Guru
430i Gran Coupe M Sport F36 -18
If you mean the "parking light" it is a 5W lamp. What do you mean with code name? Is is the BMW article code you are after? In thgat case the number is 07 11 9 978 373
mvh
MW-Guru
iv
77
ivenos
535i -88 BSR trim
I want to know the type of the lamp. For example the head light lamp type is H1 and the fog lights is H3 what is the type of the position or parking light lamps?
MW
517
MW-Guru
What I wrote is applicable for E34, for E28 it is a 4W lamp with number 07 50 9 063 576
mvh
MW-Guru
MW
517
MW-Guru
Aha, I don't know the name but if you shall change lamp and it is a E34 you have (I guess so) just pull out the long "tube", take away the lamp and go to the nearest petrol station, they have it.
mvh
MW-Guru
iv
77
ivenos
535i -88 BSR trim
Thank but since you seem to know this lamp, can you tell me if the contact is glas or metalic? Is it the same type as the side blinkers lamp?
MW
517
MW-Guru
The same type as the side 'blinkers', yes
mvh
MW-Guru
iv
77
ivenos
535i -88 BSR trim
Thanks a lot :o)
