1.267
M3 kamaxlar i M50 motorn?
Wa
198
Wardof
525i Touring
325 e30 24v
Hittade ett brev om M3 kamaxlar i M50 motor och undrar om det är någon som vet nåt om det?
Jag saxar brevet här
BMW Cam Swap
Do 1996-99 M3 cams work in the M50 engine?
Sadak Rinaldi Leite
Sao Paulo, Brazil
We spoke with Pete McHenry of Precision Performance in Winston-Salem, North Carolina. McHenry is a well-known expert on BMW engine swaps and parts interchangeability. He advises: The M50 2.5-liter VANOS cams are 228-degree duration, while S53 3.2-liter M3 cams are 252 intake and 240 exhaust. They fit fine and give a nice boost to the top end on a 2.5-liter M50. You can use the S52 cams with the M50 lifters and springs. The S52 uses smaller lifters (33mm vs. 35mm diameter) and conical valve springs with teeny retainer washers. Net saving with this stuff is 20 grams per valve. Get the S52 cam trays, lifters and springs if you can but the swap is OK with cams only as mentioned earlier. If you have a 1992 M50, you can switch the intake cam to the exhaust. Timing is 240 on both, but the intake has 9.7 lift vs. 9.0. Buy a 252 Schrick intake cam and you have the same cams as an M3 and only have to buy one camshaft.
--Mike Miller
Wa
198
Wardof
525i Touring
325 e30 24v
länken kom inte med.
bm
2.125
bmw-andreas
M3E30 963hk@950nm
passade inte på min M50 motor utan vanos allafall,men kanske på vanosen då?
Det där gäller nog us-modellen.
