Front blinkers replacement for an e34
iv
77
ivenos
535i -88 BSR trim
Anyone can help me with instruction of how to install the front blinkers on my e34? I have boght white ones and it wa snot hard to install the rear and the side ones but the front are giving me hard times, please help!!!!!
ST
2.827
STEPHAN
Alpina B10 BiTurbo -06
BMW M5 -91
BMW M3 -97
Hello,
See if you can find something useful on this site:
Good luck!
Kind Regards
Stephan
__________
Ha
152
Hasse
BMW 320 Cab -10
Hi,
I recently installed white blinkers on my E34. They were mounted from behind with two (or three) screws each. On the right side you just have to locate the screws and remove them (use mag-lite, small mirror and a medium length screwdriver). On the left side you have to remove some components that are connected to the air intake before removing the screws.
It is quite tricky and takes some time, but its not impossible!!
Good luck!
BR /H
iv
77
ivenos
535i -88 BSR trim
Thank you all for your quick responce and help!!!
The problem is that especially on the left side, i have the plastic water canister for the head lights and there is no space to put my hand inside so i can unscrew the screw that ataches the plastic ear of the blinker to the left front wing. Do i have to remove the water canister? Does that mean i have to remove the front skirt too??
I've changed from yellow to black blinkers on my car and I removed the water canister. Then it wasn't so hard to change...
iv
77
ivenos
535i -88 BSR trim
Hello there
Thank you for the respons first of all..
I have some questions about how i should remove the
water canister and in what order i have do do it?
I have unscrewed the 2 screws at the top but when
i am trying to pull the canister upwards, looks like
something is holding it stuck down..Do i have to remove the front bumper and all the water pipes?
Best regards
JV
The water pipes you just pull out. I think I did that. And the water canister, I don't think that there is anything holding it down. I just bend it up, I guess. I have two pumps on my canister and on the side there is a sensor to the check control...
I didnt remove the front bumper.
iv
77
ivenos
535i -88 BSR trim
Thank you all!!
I will try it this weekend and we will see what happens :o)
Best regards
JV
iv
77
ivenos
535i -88 BSR trim
Does anybody knows if i will be able to have a clean paper from the yearly car inspection with the white blinkers?
Best regards
JV
no
3.595
nofx16
BMWCS[syd]#5120
That shouldn't be a problem, as long as the light that shines from them is orange!
//Kalle
iv
77
ivenos
535i -88 BSR trim
Thanks kalle ;o) It is orange!! :o)
Best regards
JV
