DPF-sensor, jordfel
ja
5
janbro
320 d touring - 20
Har bara 6-volt i kontaktdonet till DPF-sensorn. Jordfel alltså, men är det någon som vet var jordpunkten på motorsidan sitter?
janbro
Dina 6 volt är kanske bara 5?
Bara vad jag kan läsa mig till:
” A metal membrane in the differential pressure sensor converts the exhaust back pressure into a displacement. which is converted into a voltage signal by 4 pressure-sensitive resistors. The measuring range of the exhaust gas pressure sensor is -0.05 to 1.0 bar absolute; this corresponds to a voltage of 0.875 to 4.5 volts.
The differential pressure sensor is connected via a 3-pin plug connection.
The sensor is supplied with 5 Volts by the engine control.”
//Lennart
