Felkoder 530 E60 2005
Bw
6
Bw1977
530 e60 2005
hejsan, har en 530 E60 so stått i några år, jag får den inte att gå,den startar men går ojämt,och dör efter 30 sekunder.har felsökt med carly och fått en hel hög med felkoder,
Finns det nån som kan hjälpa mig tyda dom,så attt jag kanske kan få fart på bilen igen.
009CB8
LM: Short-circuit fault
critical
Last occurrence:
00A8C5
LM: Right daytime driving light faulty; RR02: right clearance light faulty
critical
Last occurrence:
00A8C4
LM: Left daytime driving light faulty; RR02: left clearance light faulty
critical
Last occurrence:
00A8C3
LM: E63/E64/E65: front right direction indicator 2 faulty; E60/E61: right brake light 2 faulty; RR US: rear right direction indicator 2 faulty
critical
Last occurrence:
00A8C2
LM: E63/E64/E65: front left direction indicator 2 faulty; E60/E61: left brake light 2 faulty; RR US: rear left direction indicator 2 faulty
critical
Last occurrence:
00A8B3
LM: Direction indicator, rear right, faulty
critical
Last occurrence:
00A8B2
LM: Direction indicator, rear left, faulty
critical
Last occurrence:
00A8B9
LM: Tail lamp/brake light, right, faulty
critical
Last occurrence:
00A8B8
LM: Tail lamp/brake light, left, faulty
critical
Last occurrence:
009CB3
LM: Ride-height sensor, rear, faulty
critical
Last occurrence:
009CB2
LM: Ride-height sensor, front, faulty
critical
Last occurrence:
009CC5
LM: No message, LIN (RLS)
moderate
Last occurrence:
Engine
002796
DME: Throttle: adaptation values incorrect
critical
Last occurrence:
0028B2
DME: Speed limitation: reset
severe
Last occurrence:
00CD97
Message (torque request, active steering, 0xB1) faulty, receiver DME, transmitter Active Steering
severe
Last occurrence:
00CDA8
Message (status, instrument panel, 0x1B4 ) faulty, DME receiver, instrument panel transmitter
moderate
Last occurrence:
002830
DME: DME self-test: checksum
moderate
Last occurrence:
Dynamic Stability Control (DSC)
00D357
No message (ACC, 0x0AD)
severe
Last occurrence:
576 km
005F77
DSC: Engine management: interface
severe
Last occurrence:
576 km
005F65
DSC: DSC sensor 2, lateral acceleration, plausibility
severe
Last occurrence:
576 km
00D366
DSC: No F-CAN message (DSC sensor 2, C7)
severe
Last occurrence:
576 km
00D368
No message (LWS steering box, 0xC3), receiver DSC, transmitter LWS/RAD
severe
Last occurrence:
576 km
00D35D
No message (active steering, 0x1FC)
severe
Last occurrence:
576 km
Airbag Crash Safety Module
0093C1
Package abound / SBE passenger / SBE - passenger / Timeout ID 35H (telegram live) AFS (only E6x)
severe
Last occurrence:
44672 km
Transmission (GS 19)
005143
No message, receiver EGS, transmitter ACC
severe
Last occurrence:
82848 km
005142
No message, receiver EGS, transmitter KOMBI
moderate
Last occurrence:
82848 km
Head-Up Display
00A4F3
Message (active cruise control, 0x190) faulty, receiver HUD, transmitter ACC
severe
Last occurrence:
00A4F7
Message error (operation Head-Up Display, 0x210), receiver HUD, transmitter CCC/multi‐audio system controller
moderate
Last occurrence:
00A4FA
Message error (trip odometer reading/range, 0x330), receiver HUD, transmitter instrument panel
moderate
Last occurrence:
00A4F1
No message, receiver HUD
moderate
Last occurrence:
00A4F5
CAN: failure / error message status combi
moderate
Last occurrence:
Active Roll Stabilization
00D1DD
Message (lateral acceleration) faulty, receiver ARS, transmitter DSC
severe
Last occurrence:
00D1E4
Message (steering wheel angle, 0xC4) faulty, receiver ARS, transmitter steering column switch cluster
severe
Last occurrence:
1528 km
00D1EB
Message (kilometre reading) from the KOMBI faulty, receiver ARS, transmitter KOMBI
moderate
Last occurrence:
Air conditioning
00E71B
Message error (ambient temperature, 0x2CA), receiver integrated automatic heating / air conditioning system, transmitter instrument panel
severe
Last occurrence:
176576 km
009C78
IHKA: Washer-nozzle heating
moderate
Last occurrence:
176576 km
00E715
Message error (kilometre reading, 0x330), receiver integrated automatic heating / air conditioning system, transmitter instrument panel
moderate
Last occurrence:
176576 km
00E717
Message error (instrument panel, 0x328), receiver integrated automatic heating / air conditioning system, transmitter instrument panel
moderate
Last occurrence:
176576 km
009C55
IHKA: Fogging sensor
moderate
Last occurrence:
176576 km
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Titansilber Metallic
Hej, det var bland den längsta lista jag sett!
Det du ska fokusera på är felkoderna på DME dvs motorstyrenheten.
Resten får man ta efter hand.
Men nolla allting, ladda batteriet ordentligt och läs av igen och återkom.
Kör provstarter när du nollat allt så felkoder på motorn poppar upp igen.
Mvh Ola
Min webshop:
Mina bilar:
Bw
6
Bw1977
530 e60 2005
vi bytte styrbox för inte så länge sen, men det blev inte bättre.
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Bytte DME? Till en sprittans ny?
Mvh Ola
Min webshop:
Mina bilar:
Bw
6
Bw1977
530 e60 2005
nej,begagnad programerad från vimmerby bildemo.
olaO
M5 e39 -00
Carbon Schwartz
525ix MT -10
Ok, det är ju trixigt det där med DME, den måste ju programmeras specifikt för din bil.
Men i och med att den överhuvudtaget startar så fungerar den nog.
Mvh Ola
Min webshop:
Mina bilar:
Bw
6
Bw1977
530 e60 2005
ja,frågan är ju bara vart f.n ska man börja leta?
Finns det någonting i bilens historik som är viktigt för oss att veta?
Stått några år. Varför då?
Bytt DME, varför då?
Hur gjorde Vimmerby bildemo ? Vad utgick man ifrån?
I viket skick är batteriet? Det räcker inte med att bilen startar. En BMW kräver ett kärnfriskt. Kanske inte nödvändigtvis på topp, men inte långt ifrån.
Gjorde du som Ola föreslog? Rensat alla felkoder och sett vilka som kom tillbaka?
/Lennart
Bw
6
Bw1977
530 e60 2005
det började med att den va svårstartad när det va kallt eller fuktigt ute,sen så startade den men gick bara ca 30 sekunder så dog den,och den går ojämt när den startar.sen blev den stående.
det va nån som sa att dme va trasig,så vi skickade den gamla till vimmerby,och dom programerade en begagnad och skickade upp,men felet kvarstår,batteriet va relativt nytt,men nu vet jag inte eftersom den har stått utan ström så länge, det tar laddning iaf,och det funkar att starta,men som sagt den dör,nästan direkt.ja jag har rensat,och det är samma som kommer tillbaka.
Antalet felkoder är ju en sällan skådad svärm, som sagt.
Många av dem rör ljusmodulen. Fungerar inget ljus alls på bilen?
”Svårstartad plus kort på tomgång” skulle jag gissa kunna bero på en trött bränslepump eller åtminstone vara bränslerelaterat.
En annan ingång kunde vara vevaxelgivaren, men i så fall inte ett helt typiskt uppförande. Den brukar nog oftast ge upp totalt.
Jag hade provat att sätta tillbaka original DME och försökt lyssna mig till om bränslepumpen går. Eller åtminstone mäta bränsletrycket.
Och naturligtvis måste du se till att batteriet är fräscht. Och att det alltid underhållsladdas också.
”Stått några år” - inte en chans att det batteriet levererar!
/Lennart
Bw
6
Bw1977
530 e60 2005
jo all belysning fungerar,men får felkoder på det, det enda jag ser är att blinkersen blinkar med turbofart,fast alla fungerar,orginal dme finns nog inte kvar,den skickades till vimmerby.
Ok. Ett tecken på att batteriet är skyldigt till en stor del av koderna.
Kolla ändå med Vimmerby. Kanske den finns kvar. (Den borde ju ha skickats tillbaka till dig, tycker jag.)
Som jag ser det, är koderna på DME (delvis) en följd av att DME inte är i originalskick.
Men fixa batteriet!
Och kolla bränslet!
/Lennart
