E46 felkoder och konstig tomgång
Br
5
BroshanMittiWegen
318i Touring -03
E46 318i Touring 2003
konstig tomgång, går ojämnt och dör emellanåt, fick dessa felkoder, vad hade ni gjort? tändstift och kolla maf?
Car Scanner ELM OBD2
DTC report
Selected brand: BMW
============1==============
1341
Raw code: 1341
ECU: 12
Status: Pending fault present, Validated fault has been present during this drive cycle
Multiple Cylinder Misfire With Fuel Cut-off; Multiple Cylinder Misfire with Fuel Cut-Off
============2==============
1159
Raw code: 1159
ECU: 12
Status: Pending fault present, Validated and stored in non volatile memory, Validated fault has been present during this drive cycle
Fuel Trim Additve Bank 1 High; Fuel Trim Adaptation Additive Bank 1 High
============3==============
274E
Raw code: 274E
ECU: 12
============4==============
272C
Raw code: 272C
ECU: 12
============5==============
P0102
Raw code: 0102
ECU: 12
Status: Confirmed
Mass air flow (MAF) sensor/volume air flow (VAF) sensor - low input
Mass or Volume Air Flow Circuit Low Input
============6==============
P1159
Raw code: 1159
ECU: 12
Status: Confirmed
Fuel Stepper Motor Malfunction
