E34 1993 520i Airbag-lampa blinkar och lyser sedan konstant
To
45
Tommy54
320i -06
520i -93
Bytte nyligen lampor till instrumentbelysningen och trodde det skulle gå, utan att behöva koppla bort batteriet. När det inte gick så var jag obetänksam och slog på tändningen. Insåg snabbt misstaget och när bilen senare startades, så blinkade Airbag lampan för att sedan vara tänd utan att slockna.
Hittade en felkodsläsare men den verkar inte fungera för modeller innan 1994.
Prövade exemplet nedan utan framgång:
From the E31 forum of BF: This only works on Early E31, start of production to 09/93 With SIEMENS 5WK4 027 (65771382905) modules. This module is also found in some E23,e24,e30,e32,e34, and e36, procedure should work for those as well. This worked for mine even when DIS/INPA/Autologic, and all those others failed to communicate.
1. Turn the ignition switch to the off position.
2. Install a jumper from in pin #15 of the engine diagnostic connector to ground.(Since this is awkward to do in the timing given in this procedure, i used a small screwdriver and tapped into pin 6 at the orange x74 connector behind the glovebox, either will work)
3. Turn the ignition switch to the on (run) position but, do not start the car.
4. After five seconds, disconnect the jumper.
5. Wait another five seconds.
6. Reconnect the jumper
7. After five seconds, disconnect the jumpers.
8. Wait five seconds after disconnecting the jumpers.
9. Turn the ignition switch off.
10. Start the car. The air bag warning light should clear after approximately 10 seconds. If the light does not clear repeat the procedure. If, after three attempts, the light does not clear, there is most likely a problem with the air bag system which needs to be repaired.
by legoman67; 05-25-2014 posted in the E31 forum BF, do it at your own risk.
Har någon på forumet kännedom om en felkodsläsare som fungerar till angiven modell, för att släcka Airbag-lampan?
Tar tacksamt emot övriga tips på lösningar
bag
BMW CS #08225
E36 316i Compact -99
E34 520i Touring -94
Hade ett liknande problem med min E34:a nyligen efter att den varit strömlös. Dock en 520i -94. Fick låna ett instrument av en vän som liknar det du länkar till.
Min lampa slocknade efter en minut ungefär men lyckades släcka felkoden.
Försökte först med ett nyare instrument som är till min E36:a men det fungerade inte.
BMW - Allt annat orsakar illamående.
To
45
Tommy54
320i -06
520i -93
Vad bra. Är så pass billiga, så ska nog beställa en sådan felkodsläsare och testa.
För andra med tidigare årsmodeller än 1994 likt mig, så kan det fungera med Carsoft 6.5 eller en begagnad SiR3 återställare. SIR3 tillverkas inte längre, som jag förstått det.
