328i F31 få i n läget på växelådan med rasad motor...
bu
73
bubbi
328i touring -13
Står med en 328i f31 med rasad motor....
Behöver transportera bilen upp på ett släp ,lite svårt med lådan fast i P läget...
Vad f-n gör man??
Citat"
Unlock transmission lock electronically
Step on the brake during the entire ulocking procedure.
The transmission lock can only be unlocked as long as the starter audibly and evenly
turns, but the engine is not running.
To prevent the engine from starting during a turning starter, the fuel pump fuse can be
pulled if necessary. See fuse box installation location
 Overview of luggage compartment
1. Step on the brake pedal.
2. Press start/stop button.
Starter turns for about 20 seconds.
3. Press unlock button 1, arrow 1, and hold pressed during the entire unlocking.
4. Move selector lever to the N position for at least 4 seconds. An acoustic signal or a
text message is output, depending on the vehicle.
5. Move the selector lever back to its initial setting.
6. Move the selector lever to position N again briefly and then move back to the initial
setting.
7. Release unlock button. The display on the selector lever shows N.
The transmission lock is now unlocked.
8. Take foot off brake pedal.
The starter stops turning. The vehicle can now be rolled.
The transmission lock is unlocked for approx. 15 minutes. The unlocking of the
transmission lock extends by approx. 15 minutes for every detected rotational
movement of the vehicle. The exact duration of the unlocking depends on the state of
charge of the vehcile battery."
Saxat ut intern bmw-dokument.
bu
73
bubbi
328i touring -13
Tack för tipset!....det var till stor hjälp😃
