Batteribyte 523i
Ha
Hada
523i touring 05
Jag undrar om man kan byta batteri i 523i utan besök på verkstad?
Hoppas på svar.
HD
Sverige
Cupra Ateca -20
130i E81 -08/09
M-sport
(325xi E90 -06 såld)
(323ti E36 -99 såld)
Ja. Har bilen IBS bör dock batteribytet registreras.
38
158
38Larsson
523i -10
318i -02
Ja det kan du men....
Den vanliga frågan kommer komma upp hurvida batteriet behöver registreras eller ej. Detta låter jag vara osagt.
Gå in på realoem och kolla vad som står om just ditt batteri för din bil.
På min 2010a står det följande.
Important notice!
Compliance with the following
information and instructions for correct
battery replacement is absolutely
mandatory!
- ISTA Document
RA_61_20_Instructions_for_battery_
replacement
For additional information, see:
- Battery master document
ISTA_Document_SI_61_07_02_(875)
The original battery (battery size and
type) as indicated in the vehicle's
order specifications must always be
installed to ensure correct operation of
the on-board electrical system!
If the vehicle is equipped with an IBS
(Intelligent Battery Sensor), the
battery must be registered via the
diagnostic system (ISTA); this process
also registers the battery with the
vehicle's on-board electrical system.
Standard batteries can always be
replaced by AGM batteries with the same
specifications.
Following either type of replacement,
the vehicle registration process in
ISTA/P must be supplemented by a vehicle
coding procedure, which is carried out
as follows:
Read out battery size and registration
from onboard electrical system:
ISTA->Service functions->Body->Voltage
supply->Register_battery replacement->
Test plan
