520D felmedelande SEG
Bo
6
Bolibompa10
520d -08 E61
Jag har bytt DPF och givarna som sitter på den. EGR bytt. När turbon laddar så skramlar/rassla det lätt följer laddet/varvtalet. Ser inget visuellt fel. Ibland laddar inte turbon heller. Ska besikta HJÄLP!
Faultcode: (0x452A) Info - particulate filter system
Faultset 1:
(appeared at: 217024.0km)
AGR - actuator position (1 byte):
0,00 %
Exhaust gas pressure upstream of particle filter:
1032,00 hPa
Exhaust gas temperature before catalytic converter - corrected value (1 byte):
169,80 degC
Current gear internally:
0,00 -
Output duty - boost pressure plate (1 byte):
87,84 %
Swirl flap - actuator position (1 byte):
9,41 %
Throttle - actuator position (1 byte):
0,00 %
Injection quantity - quantity setpoint without compensation scheme (1 byte):
10,98 mg/hub
Recorded battery voltage (1 byte):
15000,00 mV
The collected value of the air temperature at the HFM-position (1 byte):
10,00 degC
vehicle speed:
0,00 km/h
Fuel temperature (1 byte):
9,00 degC
Kuehlmitteltemperatur (sensor value before correction):
51,00 degC
Charge air temperature after Intercooler (1 byte):
43,00 degC
Air pressure before the intake valve (1 byte):
956,86 hPa
Air mass per cylinder (1 byte):
508,24 mg/hub
Engine speed:
796,50 rpm
Oxygen Sensor Output - Equivalence Ratio Bank 1 - Sensor 1 0:
2,03 -
regeneration status:
1048577,00 hex
Setpoint air mass (1 byte):
1267,45 mg/hub
Ambient pressure (1 byte):
952,94 hPa
current motor status:
16,00 -
filtered accelerator sensor signal (1 byte):
0,00 %
maximum rail pressure of the last 10ms (1 byte):
329,41 bar
Faultcode: (0x41BA) Exhaust back pressure sensor
Faultset 1:
1036,94 hPa
169,80 degC
4,71 %
9,80 mg/hub
14400,00 mV
vehicle speed:
0,00 km/h
Filtered drag of the particle filter:
0,04 hPa/(m^3/h)
65,00 degC
941,18 hPa
351,37 mg/hub
Engine speed:
773,50 rpm
oil soot mass:
56,21 g
Offset for particulate filter differential pressure (1 byte):
16,86 hPa
2,03 -
1048577,00 hex
soot mass:
10,38 g
(raw voltage) - exhaust pressure before particulate filter:
2697,79 mV
(raw voltage) - exhaust gas temperature before catalytic converter:
1773,94 mV
Status - operating range for the Partikelfilterdruckplausibilisierung:
8,00 -
952,94 hPa
16,00 -
calculated exhaust gas flow rate in the particle filter (1 byte):
39,22 m^3/h
corrected differential pressure (1 byte):
58,82 hPa
345,10 bar
Faultset 2:
(appeared at: 217112.0km)
1060,93 hPa
259,22 degC
0,00 %
8,24 mg/hub
14400,00 mV
vehicle speed:
0,00 km/h
0,31 hPa/(m^3/h)
88,00 degC
956,86 hPa
426,67 mg/hub
Engine speed:
781,00 rpm
oil soot mass:
56,24 g
51,37 hPa
2,03 -
1048577,00 hex
soot mass:
26,57 g
2741,74 mV
996,57 mV
8,00 -
967,06 hPa
16,00 -
70,59 m^3/h
30,59 hPa
298,04 bar
Faultcode: (0x4933) Air system, air to EGR mass flow plausibility
Faultset 1:
(appeared at: 217032.0km)
30,20 %
Abgasrueckfuehrrate into the engine:
0,00 -
Absolute pressure upstream of the turbine:
1629,98 hPa
6,00 -
80,39 %
9,41 %
4,71 %
32,55 mg/hub
Injection amount correction from FMA / FMO:
0,00 mg/hub
14400,00 mV
11,00 degC
Gesamtsollabgasrueckfuehrrate:
7,33 -
72,00 degC
54,00 degC
1474,51 hPa
752,94 mg/hub
Engine speed:
1937,50 rpm
1048577,00 hex
955,29 hPa
16,00 -
dynamically adapted air mass:
793,90 mg/Hub
esteemed Gesamtistabgasrueckfuehrrate:
7,89 %
964,71 bar
rueckgefuehrter exhaust gas mass flow to EGR Cooler (1 byte from AsMod):
-20,00 kg/h
Faultset 2:
(appeared at: 217288.0km)
0,00 %
0,00 -
1937,00 hPa
6,00 -
80,39 %
9,41 %
4,71 %
34,51 mg/hub
-2,99 mg/hub
14400,00 mV
10,00 degC
1,64 -
88,00 degC
44,00 degC
1647,06 hPa
1022,75 mg/hub
Engine speed:
1848,50 rpm
1048577,00 hex
988,24 hPa
16,00 -
1028,50 mg/Hub
0,00 %
988,24 bar
-50,00 kg/h
Faultcode: (0x4C5E) particulate filter system
Faultset 1:
(appeared at: 217160.0km)
Exhaust backpressure before particulate filter - corrected:
1067,00 hPa
192,16 degC
0,00 %
39,22 mg/hub
14400,00 mV
vehicle speed:
53,00 km/h
Filtered drag of the particle filter (1 byte):
-0,02 hPa/(m^3/h)
28,00 degC
2133,33 hPa
1399,22 mg/hub
Engine speed:
2215,50 rpm
oil soot mass:
56,24 g
0,00 -
corrected particle mass additive:
0,00 g
1048577,00 hex
Raw value of the corrected absolute back pressure (1 byte):
48,82 hPa
997,65 hPa
16,00 -
462,75 m^3/h
distance traveled since the last successful regeneration:
394198,00 m
filtered differential pressure of the particle filter (1 byte):
2,35 hPa
continuously simulated particle mass:
6,11 g
2,35 hPa
1231,37 bar
Mvh Rickard
Bo
6
Bolibompa10
520d -08 E61
Fixat nu efter 1år letande. Hittade bla en tempgivare som sitter på tryckröret mellan intercooler och gasspjället. Runt anslutningen läkte det runt halva anslutningen var lös, limmade den med superlim. sedan rengjorde jag LMM med elektronikrengöring!. Bytte även givare 11747810831. Nu Funkar pärlan som den ska!
FA
1.429
FAF
X4 30d -16
Bra med återkoppling!!
FAF
