felkod 2A98 och 2A82 hör dessa felen ihop bmw e60 2005
mickenorrk
523 limo e60 -05
byte kamgivare hjälpte inte m-lampa tändes igen,kan de vara solenoiden på intaget
hjälp om ni kan
mvh Micke
Ja, felkoderna verkar höra ihop.
• 2A98 Crankshaft-inlet camshaft, correlation- Value outside reference range
• 2A82 VANOS intake- stiff, jammed mechanically
Kan definitivt vara VANOS-intake-solenoiden. Kan även vara en enklare fix - se nedanstående Service Bulletin (men kan även vara så att du behöver byta VANOS-intake-solenoiden).
SI B 11 05 05
Engine
December 2006
Technical Service
This Service Information bulletin supersedes S.I. B11 05 05 dated November 2006.
SUBJECT
N52 Engine Runs Poorly with Camshaft Sensor and VANOS Faults
MODEL
E90 (3 Series), E60 (5 Series) with N52 engine produced from 3/2005 through 6/2005
E90, E91 and E92 (3 Series) with N52KP and N54 engines from 7/2006 production
E85 and E84 (Z4) with N52 from 1/2006 production
E83 (X3) with N52 from 9/2006 production
SITUATION
Vehicles equipped with the N52, N52KP and N54 engines may be difficult to start, run rough and have the "Service Engine Soon" light illuminated.
Any of the following camshaft sensor or VANOS faults, as well as various misfire faults, may be stored in DME fault memory.
• 2A9A Cam sensor, inlet signal – signal invalid for synchronization
• 2A9B Cam sensor, exhaust signal – signal invalid for
synchronization
• 2A99 Crankshaft- exhaust camshaft, correlation- Value outside reference range
• 2A87 VANOS exhaust- stiff, jammed mechanically
CAUSE
VANOS solenoid valve is jammed or sticking.
CORRECTION
On a customer complaint basis only, perform the diagnosis and repair procedure as described below.
PROCEDURE
E90 (3 Series), E60 (5 Series) with N52 only:
Remove the VANOS solenoid, intake or exhaust depending on the fault codes stored, and using shop air, gently blow out any visible particles and reinstall.
It is no longer necessary to replace the VANOS solenoid on the N52 Engine.
Reprogram the vehicle using CIP17.01 (Target data Status E89x-05-06-510), or higher for the E90 and Target data Status E060-05-06-500, or higher for the E60.
The modified MSV70 DME data contains additional VANOS solenoid activation logic to flush out any foreign particles.
E90, E91 and E92 (3 Series) with N52KP and N54 engine, E83, E85, E86 with N52 engine only:
Swap the faulted VANOS solenoid with the opposing solenoid to verify if the fault follows to opposing location. If the fault follows replace the VANOS solenoid.
PARTS INFORMATION
Part Number Description Quantity
11 36 7 516 293 VANOS Solenoid 1
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code Refer to KSD
mickenorrk
523 limo e60 -05
tack bmw-slangen
ska ut o byta solenoiderna o rengöra dem nu på förmiddan,men som ja förstår så måste man köra nått program efter bytet eller fattar jag fel?
tacksam för svar
mvhmicke
Jag skulle gissa på att omprogrammeringen de refererar till är en modifiering av kontrollogiken av VANOS-enheterna för att aktivera VANOS-enheterna och få bort eventuellt mer skräp som inte fastnade i VANOS-enheterna. Om det bara är en temporär testprocedur eller om det är en permament ändring i styrmjukvaran vill jag vara osagt.
Men syftet verkar vara att verkstäderna ska kunna rensa bort allt skräp utan att kunden ska behöva komma tillbaka några dagar senare för att upprepa proceduren.
I ditt fall kan du kanske behöva upprepa proceduren en gång till - för det låter ju logiskt att det kan finnas lite mer skräp liggandes som inte fastnade i VANOS-ventilerna och som man vill ha bort.
Men eftersom dessa VANOS-ventiler är relativt lätta att komma åt så borde det inte vara alltför mycket extra jobb.
Dessa VANOS-ventiler har diskuterats förr, och jag vill minnas att de har ett typ av filter just för att det inte ska komma in massa smuts. Eller så är det som så att det sitter ett filter och det har mycket riktigt fångat upp all smuts och det är den man blåser bort i ovan nämnda procedur.
Oavsett så finns det numera många komponenter i motorn som är mycket känsliga för oren olja. Därför förvånas man gång efter gång över de extremt långa oljebytesintervallen och leksaksoljefiltren som sitter i motorerna numera.
EDIT : Ok, det verkade vara VANOS-solenoider för tidigare motorgenerationer (typ S54) som hade ett sådant utbytbart filter i änden
Den typ av VANOS-solenoider som sitter i dessa motorer verkar inte ha något filter på sig - gissar på att filtret sitter någonannanstans!?!
mickenorrk
523 limo e60 -05
har nu rengjort solenoiderna o har även bytt plats på dem ,så får vi se om felet kommer på den andra nu,
finns de andra sätt o rengöra vanos?
får se på måndag när ja åker till verkstad o nollställer felkoderna,om de kommer tillbaks eller inte...va tror du?
Jag tror inte VANOS-enheten (eller några andra enheter för den delen) tar åt sig från vad jag tycker och tror :-)
Det kan gå hur som helst, alla möjligheter är tänkbara i detta stadie. Men *om* felkoderna inte kommer tillbaka så ser jag det som en framgång och tummen upp för din insats - enkel fix som kostade minimalt med tid och pengar.
Skulle det komma tillbaka felkoder så får man ta det därifrån, hur man går vidare beror ju till stor del på vilka felkoder som kom tillbaka. Men även om felkoder skulle återkomma så tycker jag ändåså du gjort rätt i att försöka med de enklare/billigare alternativen först.
Keep us updated i den här tråden!
Men det var mycket bra att du bytte plats på insug och avgas förresten!
mickenorrk
523 limo e60 -05
hej
som ja skrev rengjorde jag solenoiderna i lördags o bytte plats på dem lampan lös fortfarande,hade tid till verkstan mån kl13....tyckte bilen gick ännu värre på måndags morgonen kl 8.00....åkte o handla lite innan verkstads besöket..sen på väg dit så märkte ja att lampan inte lös hmmm tänkte ja kom tillverkstaden nollade felkoderna i minnet åkte därifrån o fortfarande ingen lampa tänd....så kanske var att solenoiderna var så pass skitiga...
hjärtligt tack bmw-slangen
Ä
Si
Simonato
BMW e91 325ix
Hade dessa felkoder och min bil skakade och gick på 3 cylindrar. Fick tips om att byta solenoiden till insugssidan. Gjorde det och bilen går klockrent igen. Prövade först att bara göra rent dem och då fungerade det ett tag men problemet återkom.
