Max vrid 540?
51
129
518 I STARTEN
535XDT-12 M-sport.
vid vilket varvtal ger den mest
540is
E39 M5 99' Bi-Kompressor
E39 540iAT 00' Kompressor
M60
ENGINE & ELECTRICAL
Type DOHC (4-cam) 32-valve V-8, 4 valves/cylinder
Camshaft drive Primary and secondary duplex chains
Valve actuation Hydraulic lifters, bucket-type
Induction system Thermoplastic intake manifold, single-path cylinder runners
Bore x stroke, mm/in. 89.0 x 80.0/ 3.50 x 3.15
Displacement, cc/cu in. 3982/243
Horsepower @ rpm, SAE net 282 @ 5800
Torque @ rpm, lb-ft. 295 @ 4500
Compression ratio 10.0:1
Engine-management system Bosch HFM-Motronic with knock control
Fuel requirement 91 pump octane, unleaded premium
Emission control 3-way catalytic converter, Lambda oxygen sensor, closed- loop mixture control (50 states)
Alternator rating, amp.watts 140/1960
Battery capacity, amp-hr. 85
51
129
518 I STARTEN
535XDT-12 M-sport.
Tackar för det snabba svaret har letat en timme Det fattas bara reg besiktning så blir det 540IT 6 vxl
540is
Välkommen till V8-grabbarna :)
