1-Serien
8.682
Elfel i min 120D -08
No
4
Noxxen
BMW 120d -09
Har fått extrema problem med min bmw :(
Plingar o blinkar o allt lever sitt eget liv, ABS, DTC, Antispin, Servic blinkar, hastighet och varvmätaren dör.
Filmade händelsen Länk
Vill inte lämna in kärran för bmw i nrkp inte kan ge mig ett fast pris vad notan kan gå på
Felkoder jag får upp :
Motor Control:
Engine / Motor
Fault: Message failure
Code: 4993
Fault: :Message
Code: 497F
Code: 4BF7
Fault: :unknown failure
Code: 4B2D
Code: 49A2
Fault: :Message driver recognition
Code: 4C9C
Fault: unknown failure
Code: 4AB8
Code: 4C18
Code: 4BF3
Code: 412F
Code: 4578
Code: 4BF8
Code: 49A3
ABS / DSC / Brake:
Airbag:
Airbag
Fault: Co-driver
Code: 93C1
Fault: Bus communication error
Code: C947
Fault: General Bus Wiring error
Code: C944
Fault: speed signal is missing
Code: 93FB
Instrument cluster:
Heating / AC:
Air conditioning / Klimaanlage
Fault: CAN message
Code: E727
Fault: Message Error PT CAN
Code: E707
Fault: outside temperature
Code: E715
Fault: CAN message
Code: E728
Fault: CAN message
Code: E717
Fault: CAN message
Code: E71A
Fault: CAN message
Code: E71C
Fault: CAN message
Code: E72E
Immobilizer System:
CAS
Fault: CAN bus_off
Code: D907
Fault: Signal detection error rate
Code: A0B5
Code: A118
Fault: Error starter KL50
Code: A0B3
Systems:
Junction Box Passenger / Beifahrer
Fault: K-CAN communication
Code: C907
Fault: :K-Can failure / Terminal status timeout
Code: C91E
Fault: PT CAN failure
Code: C914
Fuel pump / Kraftstoffpumpe
ECU OK, no Fault Code
Car Communication Computer CCC
Fault: The Central Registry is incorrect
Code: E1CF
Fault: Long and / or frequent Unlocks
Code: E1D1
Fault: :unknown fault
Code: E1C4
Fault: Ring break diagnosis error
Code: E1D0
Fault: Overtemperature shutdown due to malfunction Tempshutdown
Code: E1D2
Body:
Fussraummodul /FRM
Fault: :unkown failure
Code: E599
Code: E597
Fault: :steering angle timeout
Code: E594
Fault: K-CAN Controller
Code: E587
Other:
Steering /Lenkung
Fault: :Steer angle
Code: D516
Tänkte se om någon har någon ide vad det kan vara, så man kan felsöka själv o slippa dyra reprationer på verkstad
Mvh Noxxen
We
970
Weiman
118i M-Sport -24
Ser ut som samma fel:
"Yeah all fixed. Was the unit that control the parking sensors. It's found in the well behind the rear lights on the right hand side. The well fills with rain water and damages the control unit shorting out the cars other electrics. I just removed it and places it in uncooked rice for a few days to dry it out. Hope you can fix yours !"
No
4
Noxxen
BMW 120d -09
Har tyvärr ingen parkeringshjälp kärran
Prova ladda batteriet, urladdat batteriet kan ge konstiga fel
AlexanderK
I3s 120
Z4 E89 23i manuell
Spontant säger jag också: prova med nytt batteri eller ladda det gamla ordentligt.
Håller med dem andras förslag och säger byt batteri.
/ Pella
No
4
Noxxen
BMW 120d -09
Var inte länge sen jag bytte batteri. Men problemet verkar har löst sig efter man gjort rent genomföring vid batteriet. Men skulle vilja slå idioten som satte kablarna under bilen, rent utsagt idiotiskt lösning att dra strömmen på
AlexanderK
I3s 120
Z4 E89 23i manuell
...ja, det var ju idiotiskt av den som bytte batteri att inte göra rent vid genomföringen i så fall? Vem kan det ha varit som var så dum? :)
