6.871
M Performance
He
336
Henke77
520xd,IE Touring, 2019
i3s- 2018
Det skall komma ett nytt M Performance paket till 330d/530d.
Powerkit 330d/530d 3-series (F30, F31, F32, F33 5-series (F10, F11) Automatic
330d, 330xd
– Acceleration from 0 - 100 km/h, approx. -0.2 seconds compared to series models. Vmax as series.
530d, 530xd
– Acceleration from 0 - 100 km/h, approx. -0.15 seconds compared to series models. Vmax as series.
Supplied package
– New engine control unit including engine data update.
– More powerful charge air cooler.
– BMW M Performance Power Kit aluminium badge.
– BMW M Performance sticker for side skirt.
He
336
Henke77
i3s- 2018
Fick ju inte med all information, här kommer mera info, någon som beställt?
Product description
The engine power of the production vehicles
330d, 330xd, 530d and 530xd is significantly enhanced with the M Performance Power Kit.
The kit comprises a new control unit including an engine data update and other hardware components (such as a charge air cooler) that are perfectly coordinated with each other.
The power improvement (210 kW/600 Nm*) is truly thrilling thanks to its sporting character and impresses with outstanding driving performance.
Sales features/benefits
– Thrilling driving performance, sporty, dynamic coherence and rapid responses.
– Excellent traction, even at higher speeds.
– Fuel consumption and emissions in the ECE driving cycle as for basic engine models.
– Higher torque curve, maximum 600Nm* at 2000 rpm.
– Higher power curve, maximum 210 kW at 4000 rpm.
– Brakes upgrade on the front axle from 17" to 17" HP
JF
118
JFR
F10 M5 -12
F11 525dAM -11
Fel fokus. Hade varit mer intressant om de fått till liknande ljud som i Audis färska stora trenolla.
jh
1.252
jhellstrom
BMW 520D Touring 2012
Någon som hört mer om detta?
Wi
2.100
Wiberg
iX40 -24
X3 30e -23
Det är så vitt jag vet några på UK-delen av f30post.com-forumet som installerat detta. Kolla in denna tråden, tror det finns en del intryck från dom lyckliga ägarna där: Länk
AlexanderK
I3s 120
Z4 E89 23i manuell
Det finns ett jättestort reportage om M performance i reportage-fliken.
Engine-power-kitten brukar göra ca 10% på effekten och består av (alltid) större/förbättrad laddluftkylare och (alltid) ny styrbox samt (ibland) större fläkt.
Siffrorna du nämner är helt korrekta. Vi har även provkört en 330d med just M performance-kit och den var galet rolig kan jag lova.
På tvålitersdieslarna gör den 15-19 hkr beroende på modell. Observera att alla siffror som nämns i produktbeskrivningarna är BMW:s egna jämförelser i körcykler, så verkligheten är förmodligen något bättre eftersom företag alltid är rätt så försiktiga i måttuppskattningar.
Dessutom är bilen fortfarande typgodkänd och premien ändras inte heller.
Wi
2.100
Wiberg
iX40 -24
X3 30e -23
Det stämmer för dieselkiten men för bensin (i alla fall x35i, power kitet för 428i verkar inte finnas än på realoem) så är det varken ny laddluftkylare eller större fläkt. Ny styrenhet krävs på bilar före 11/2012 men för bilar tillverkade efter det är det bara en mjukvaruuppdatering i befintlig styrbox.
Duckblade på forumet har monterat PPK på sin 330d och han skriver lite om sina intryck i tråden Länk
Det står rätt bra om M Performance även på BMWs egen hemsida.
