F10 2013 Facelift BILDER!
Känns lite tidigt..
Bilder: Länk
The overall look is taken from the 2010 BMW Concept Active hybrid 5 in regards to the lower intakes.
The 5er will be offered with adaptive LEDs as an option , updated taillights and reprofiled rear diffuser.
Front wing mirrors with side indicators.
The next-gen six cylinder engine that will premiere with the F32 BMW 4er Coupe in spring will feature as will a petrol powered EfficientDynamics model. And rounding off will be the usual interior trim , exterior colour and wheel re-designs.
The priority changes are to the steering which is reconfigured to be more communicative. A more class-leading ride and dynamic proficient handling updates in order to improve the overall impression of the car.
qsacage
BMW i4 M50 (G26) 2022
"Front wing mirrors with side indicators."
Neeeeeeeej!!
Det ser ut som att det kommer en ny rak sexa samt varje 5-Serie ink M5 ska vara faceliftade under sommar 2013.
The new In-line six is part of the new range of EfficientDynamics engines it replaces the N55 and it debuts in the 4er Coupe first (Which is now in FEP) . The new engine also incorporates BMW's Cylinder dimming from the larger V8.
BMW aim to be at the forefront of new engine technology roll out for a wide variety of cars.
The 5er Sedan , Touring and Gran Turismo which will be facelifted at the same time will be unveiled in the summer prior to the IAA in September 2013 when they will arive on the market. The M5 will follow after.
DL
1.813
DLC
G21 M340i -21
Var hittar man info om nya sexan?
Infon kommer från SCOTT27 på Germancarforum.com och bimmerpost.com.
Han jobbar med utveckling av bilarna, tror det är på ritbordet.
Kommer ofta ut med massa nyttig info om vad som skall komma.
