BMW felkod M3
Ku
102
Kushter
E92 BMW M3 2009 DKG
Hej körde min bil idag BMW M3 DKG E92 09
STOG stilla vid rödljus gasa fult på neutral ! Sätter i växel kör normalt då dyker ett kugghjul up står transmission något bl.a. Bl.a. Att jag ska åka till BMW eller ringa dem! Startar om bilen bilen går bra precis som vanligt i växelåda! Aldrig fått andra felkod eller denna.
Vad kan ha hänt ? Något jag behöver kolla up?
Tack
Ku
102
Kushter
E92 BMW M3 2009 DKG
Felkod försvann efter starta om bilen
Bi
3.800
Bianca
130iM-Sport LCI E87 2009/12
kasst/dåligt batteri
Bi
3.800
Bianca
google är din vän..
I've been having the same issue with my 2004 525i. It sucks when you're in traffic and can't pull over! So all I did was also shut down the car and then restart it after 5 seconds and it went away. My BMW service advisor told me it could be that the transmission had remembered the driving habit from the previous owner.
So I reset the transmission memory today (12/20/2010) and so far it has solved the issue. The transmission shifts smoother and upon coming to a stop the trans doesn't jolt into 1st gear; so I guess I'll see what happens from here.
