antal givare och kablar till kylningen bmw e39
muru_skyline
535 sedan 1997 med 540 motor
HEJSAN!
HAR BYTT REMMARNA OCH FLÄKTRAMEN OCH EXPANSIONSKÄRLEN TILL MIN 535 1997, M62 MOTORN OCH JAG HAR PROBLEMET NU ATT JAG HAR EN MASSA KABLAR SOM JAG INTE VET VART DE SKA. hAR ÄVEN PLOCKAT NER EN HEL DEL AV BILEN, KAN JAG TILLÄGGA. BL.A STRÅLKASTARNA.
SÅ MIN FRÅGA ÄR, JAG HAR KOPPLAT TILLBAKA KABELN TILL SJÄLVA KYLAREN(SENSORN) SOM LIGGER TILL VÄNSTER OCH TILL EXPANSIONSKÄRLEN. SKA DET FINNAS NÅGOT MER? BÖRJAR BLI HELT NOJIG EFTERSOM JAG HAR TOTALT 4 KABLAR KVAR PÅ VÄ SIDA, MEN PÅ HÖGER SIDA HAR JAG BARA 3 TILL STRÅLKASTARNA, OM MAN INTE TÄNKER PÅ DE TILL BLINKERSEN. ALLA KABLARNA PÅ VÄ SIDA SITTER IHOP OCH JAG HITTAR INTE OM JAG SKA TRYCKA IN NÅGONSTANS EN TREDJE KABEL!
FINNS DET NÅGON SOM KAN HJÄLPA TILL LITE? HAR ÄVEN KOLLAT LITE PÅ REALOEM OCH HITTAR BARA 2 SENSORER TOTALT.
TACKSAM FÖR SVAR!
