Lossa stötfångare e61 -08
Hej igen.
Ska lackera om stötfångaren bak på min BMW och undrar därför hur i hela friden den sitten. Kan någon ge tips på en guid eller något så vore jag glad.
E4
82
E46r
BMW 523ia E39 - Alpinvit
The procedure is very similar to the E60,
Undo the screws at the rear of the wheel arch, as well as removing the little plastic rivet each side underneath.
Remove the rivets from under the centre of the bumper at the back.
Remove the covers adjacent to the rear lights and undo the screws that are revealed.
Gently pull the front of the bumper away from the wheelarch, away from the side of the car, to release the bumper.
Then, with assistance, pull the whole bumper rearwards.
Don't forget to undo the PDC wires when you get a bit of clearance.
It looks easier to do on the E61 than the E60 because you don't have to remove the inner side panels - although you'll be removing them for doing the wiring anyway.
