3.725
felkod P0135
te
22
telgetok
740ia -00
520da touring -08
Motorlampan börja lysa på min e38 740 så jag kollade felkoder, fick fram felkod P0135, O2 sensor heater circuit. Vad menas med detta? Hur fixar jag det? Nån som vet?
telgetok
Ar
83
Armand
530xD Touring -17
En av lambdasonderna är nog kass, P0135 O2-sensorvärmare (bank 1, sensor 1).
Hittade nedanstående på ett engelskt forum.
Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
What does that mean?This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
Symptoms:
You will likely notice poor fuel economy the illumination of the MIL.
Causes:
A code P0135 may mean that one or more of the following has happened:
•O2 Heater element resistance is high
•Internal short or open in the heater element
•O2 heater circuit wiring high resistance
•open or short to ground in the wiring harness
Possible Solutions:
•Repair short or open or high resistance in wiring harness or harness connectors
•Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
hasso
520i-1989 Alpinevit II
BMWCS 04247
Monark 50S 69-71
Yamaha xs400 12E Seca -82
Honda CB 650-82
Captur Intens II-19
PO135 motsvarar BMW kod 13 på en M62-00.
En testsignal säger att du har avbrott till eller i uppvärmningen av lambdasonden efter att signalen har kollat den inre resistansen med en kalibrerad spänning.
I princip byt lambdasond före katten på cylinder 1-4 bank 1 passagerarsidan.
///MVH Yngve "Hasso" Carlsson
te
22
telgetok
740ia -00
520da touring -08
Tack för mycket bra svar. Nu vet jag vad jag ska göra.
telgetok
