bränslepumpen till webastovärmaren var?
ka
183
kallevh
320 I-98
330 ci cab -02
SAAB 9-5
Hej någon som vet var bränslepumpen till webastovärmaren sitter ??
jag har en E46- 330 cab -02 original monterad är den..
rob_t_j72
XC70 D4 2015
Borde ligga nära tanken?:
"The fuel pump took some time to install, but only because it is fiddly working in the restricted space around the fuel tank"
"The dosing pump really wants to be fitted near the tank, from the install manual"
"All the restrictions about installing near the tank and the installed height are to do with the pumps ability to draw diesel. It's a push pump driving into a very small pipe, and pumps are generally only good at push OR sucking, not both"
ka
183
kallevh
320 I-98
330 ci cab -02
SAAB 9-5
Tack ska kolla
