E61 touring 2008: rear window opens + distance measurement and time resets
Lubo-Täby
525dA Touring -08
Hej på alla,
I have 2 problems with my E61 touring 2008 model:
1: during the night when car is parked the time and distance measurement resets itself, almost every time.
2: after starting a car, sometimes back window on
Programmer
F11 530dX M-sport -16
Golf GTI -18
A good start is to make sure You battery is fully charged. Get an intelligent charger like CTEK and let it charge overnight or even longer. This i recommended to do a few times every year and will increase the battery lifetime.
I can't tell if this will solve Your problems but a weak battery can cause all sorts of strange issues...
//Ulf
Lubo-Täby
525dA Touring -08
TAck Ulf,
Jag ska prova at lada bateriet.....
Other problem is that after starting the motor, the back window (backlucka) opnas själv?
It was very cold this winter as you know and there was a lot of ice between glass and doorframe (snow was melting on the window and freezing immediately under and arroud it), so I am scarred that it could damage the microchip in opening handle. I guess by the discussions I Googled...
LL
909
LLoydan
Audi Q7 50tdi
If the back window opens by itself it is most certainly moisture in the micro switch. I just had mine replaced and it solved my problems!
Anders-72
525i Touring -01
Probably as LLoydan says about the switch. In some cases the cables between the body and back door gets worn especially in cold weather. That can be no.2 to check if it´s not the switch.
The shelf underneith the rear window is always a problem in the winter causing snow to stay there. The wiper will also have problems cleaning the window as snow packs up at the shelf.
Lubo-Täby
525dA Touring -08
Hej LLoydan,
how much did you pay for replacement of the micro switch?
LL
909
LLoydan
Audi Q7 50tdi
1700 kr, work included at BMW.
