6- och 8-Serien
2.110
Some help needed with my car in Stockholm
KK
KKnD
635CSi - 86
Hello people! It's a nice site you have here!
I've recently moved to Sweden - and yup, I drove a 24 years old car 3000km to come here.
I would greatly appreciate if you would share some common knowledge with me since I don't speak Swedish (yet)...
First, I'm interested in where can I get original BMW parts cheapest - I might need these, cause I do most of the work on my car myself.
Second, my car has, few days ago, developed a small water leak inside the cabin, and I am pretty sure that the windscreen sealing gone bad is the culprit. I want to know who (or which company) could be able to pull out my windscreen, change the sealing (a 650kr part) and put everything back, for a reasonable price. I checked with the local dealership, and they want 4000kr for the labor alone - plus they don't guarantee that they won't break the windscreen... I think it's too much for something like 30 min. job. If it's against site's policy to advertise in any way, please send me a personal message...
Many thanks in advance!
Cheers!
p9
95
p950nlu
540iA Touring -01
Porsche 928S4 -89
Ford Mustang Fastback 1966
carglass has reasonable prices
M6
5.185
M635 forever
Swe E24 M6/M635 register
E24 M635Csi -84
E34 535i -92
E87 120D -08
E61 535D LCI -08
BMWCS #5984
BMWSC #481
Where exactly did you find the water, driverside or passengerside (i assume its a lhd car)?
If its on the passenger side and your car has sunroof, it might be the drainhose from it that got a leak.
If not, and youre still got plans to change it, its not that hard to do it by your self with a little help from someone.
The hardest part is to pull out the chrome frames without bending them to much.
Mvh Patrik
KK
KKnD
635CSi - 86
Thanks a bunch for the input!
It's a lhd car, without a sunroof. So that is ruled out.
The water is driping from behind instrument cluster to knee panel (the big panel below steering wheel).
From there it drips down to the floor mat.
I had a bigger leak problem, that I solved by sealing wiring loom holes (ECU wire loom etc.) with silicone. This is not it, since the water is driping from above, instead of running under the carpeting.
I will probably look up carglass, since I do not have neither tools nor a hand for help right now at this moment. And I have to do it before winter - if the accumulated water freezes there, things will go south very fast :)
Thanks again! Your help is most appreciated!
