turbokitt e30 m20b25
kan detta kitt vara något är väldigt sugen på att köpa detta. då det är väldigt bra pris.
For 84-91 BMW 3-Series
with E30 Chassis / M20 Engine, 6 Cyl, Convert to Top Mount T3 /T4 Turbo. Bolt On fit
GT35 Turbo Kit + Downpipe + Oil Kit + 3" Exhaust System
* Re-designed New manifold, Clears Oil Filter, Turbo Moves forward.
* 3" Downpipe, V-band
* 38mm Wastegate, 8 PSI, External
* GT35 Big Turbo, Up to 400 HP
* Comes with Oil Sandwich and Oil Line. Bolt on fit.
* 3" Catback System, 7" Big Muffler with Deep Sound, 4.5" Tip
We developed a few products for the E30 and fully tested and dyno. The car we used is a 89 325I Stock Engine, Stock Fuel System. According to BMW, this engine produces 168HP and 166 ft-lbs when the car was brand new. We did not dyno the car before the mod, but after almost 20 years in use, we estimate the actual power is around 125HP and 130 ft-lbs. These are the #s we got from dyno:
* NA Header with 3" Catback: 152 HP, 165 ft-lbs
* GT35 Turbo kit with 3" Catback: 211 HP, 205 ft-lbs
These #s are very good, consider the engine and fuel system is 100% stock. we Believe with proper Built Engine, fuel system and tuned, our turbo kit can produce around 400HP. NA Header can produce 180HP.
