Problem med smg låda 330
bå
1
båt
330-03
328-99
Lådan är låst i 1ans läge bilen går ej att starta har koplat ut batteriet over natten men felet kvarstår. är tacksam för svar.
rob_t_j72
XC70 D4 2015
Kanske dessa SMG1-trådar kan hjälpa?:
"Solution to E46 Non-M3 SMG problems:
The SMG relay in my 2005 330Ci is black and NOT the salmon color. I ordered the comparable part, Cost $14 (Part #61366901469). It was alittle difficult to compare the part#'s and descriptions to find the exact piece but I believe I solved the different parts identities, so non-M3 SMG cars can have the same cheap and fast fix for their problems with the SMG pump malfunctioning. My problems had to do with starting the car and not being able to switch the car from Gear1 to N, in order to get the engine to start."
Took pictures of my engine electronic box:
Link to my picture postings.
Pic 1: Engine Electronic Box (NO Salmon Relay), Only Black Relay
Pic 2: Relay Motor Switch (Part #61366901469) = Salmon Relay Switch
Pic 3: M3 engine electronics W/ Salmon Relay Switch (NOT MY CAR)"
Länk Länk
