Microfilter byte E60/E61
Sida 2 av 2
pr
259
protos
E60 520I-04
Tror ni att bilverkstäder(icke Aukt. bmw) köper service och slitage detaljer från BMW original ???
Givetvis finns det alltid 2-3st kvalitetsleverantörer till varje detalj.
Dessa verkstäder lämnar samma garantier också.
BMW tillverkar inga filter
T.o.m BMW köper reservdelar från bilreservdelsgrossister.
Mann,Fram,mfl filter används också i tuffare och dyrare miljöer än i bilar.
I industri och till sjöss 24tim drift årets alla dagar.
Varför denna rädsla??
(Biltema är lite tveksamt varierar högkvalitet med skit)
bm
115
bmw145
530D-11 F07
116 -05
z4 coupe -06
Hur var det med nollställningen ? av
Fr
1.147
Freude am Fahren
330E xdrive touring -25
Busenkelt: från e60.net. se punkt 6
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Att notera är att det är viktigt att snabbt trycka igen efter uppsläpp när du kommit till den ikon du vill nollställa
Ja
118
Jasko
530i -06
Hej har samma problem med microfiltret stod 900 km kvar till byte när jag köpte bilen nu har jag enbart kört 400 km och det står att det har överskridit själva bytes grönsen och där står 18000 km förstår ingenting för allt var okej o bra o nu har det bara sjunkit någon som förstår vad problemet är ?
Ja
118
Jasko
530i -06
På avanstående menade jag såklart att det stod minus 18000 km att det har överskridit fast för 2 dagarsen stod det 900 kvar till byte och jag har som sagt bara kört ynka 400 km hur kan det bli såhär ?
jz
M.
1.858
M.A.
320d Touring -17
320d Touring M Sport -21
Tackar för länken med instruktioner på hur man byter. Ska göra detta nu i veckan. Var och handlade nya på Auto 7H i Uddevalla för några dagar sedan.
Reservdelskillen hängde med ut och nollställde service-indikatorn. Så full pott till Auto 7H för excellent service.
