BMW "Spicup", har denna funnits på riktigt?
Har en låda med gamla leksaksbilar ifrån min barndom och hittade en bil som enligt undersidan är en BMW "Spicup". Den ser ut som en blandning mellan den klassiska Fiat X coupen och Porsche 917, fast med BMWs njurar och 4 runda strålkastare. Dvs en tvåsitsig bil med något slags targatak(?).
Har denna BMW modell funnits på riktigt? Om så är fallet, har någon lite mer info om modellen?
Tack på förhand!
nu
130
nulle
320i Touring -06
328i Coupé -96
ta
27
tape
530da x-drive Touring -15
Verkar vara nån typ av koncept bil från 1969
www.google.se
Den verkar alltså finnas, tack för länken synd att man inte är något vidare bra på ryska :-)
nu
130
nulle
320i Touring -06
328i Coupé -96
Vilken tur att det står på engelska då.
Bertone’s choice of name for this design took him away from his usual source of inspiration, the world of nature (think of the "Carabo", and the "Miura" etc.). With this car the Turin designer opted for a name which expresses the theme of the car, that is, its metamorphosis between spider and coupé and back again: the name Spicup is in fact spider + coupé. The Bertone design is a reworking of the glorious 507 Spider produced by the German carmaker. It is based on the chassis of the 2500 saloon, shortened from 269 cm to 234 cm, with a 2800 cc. engine, which was already being mounted on the coupé presented by BMW in the same period. The considerable dimensions of the mechanical components were handled by creating almost excessively fluid vertical lines. At the same time, the relatively important tail and wings become the car’s focal point. The rollbars had to satisfy a combination safety needs and design criteria, and Bertone solved the problem with an automatic mechanism which also contained the elements for the transformation from spider to coupé and back again.
The Spicup was presented at the 1969 Geneva Motor Show.
Source: www.bertone.it
Snygg bil!
The way we see the problem is the problem.
amullo
-18 F31 320da x-drive Msport
-10 Ducati Multistrada 1200s
Den var f*n ganska cool.
Påminner om gamla Corvette Stingray i fronten tycker jag.
//amullo
nulle: Tack för vänligheten ;-) Första länken funkade inte när jag försökte gå in där. I andra länken finns dessutom bild och text om leksaksbilen ifrån "Playart".
