Vill ni ha förklaring på era felkoder så har jag det!
Sida 5 av 5
F-
1.931
F-Tar
Alpina B5 2005 #001
BMW 325tds 1997
P0135
Technical DescriptionOxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
What does that mean?This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135.
SymptomsYou will likely notice poor fuel economy the illumination of the MIL.
CausesA code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
Possible SolutionsRepair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
P0014
P0014 - "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
OBD-II DTC Trouble Code Description"B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
What does that mean?A code P0014 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0014 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. Bank 1 is the side of the engine containing cylinder #1. The "B" camshaft shall be either the "exhaust," "right," or "rear" camshaft. Left/Right and Front/Rear are determined as if viewed from the driver's seating position.
Potential SymptomsMost likely a P0014 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
CausesA P0014 DTC trouble code may be caused by one or more of the following:
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed timing valve control solenoid (stuck open)
Possible SolutionsThis DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
SIDAN: Länk
ma
222
mats_hajen
320i Touring -96
320i Sedan -93 Reservdelsbil
Audi A4 Avant 2.0tdiQ -08
Skulle gärna ha en svensk översättning på felkodslistan till E36 (-96 med m52).
Har ett gäng koder ja skulle behöva kolla upp!
matshajen@gmail.com
uf
3
uffesall
530i sedan -07
320i sedan -99
Felkod P3284 530i -07
Hej! Vet du vad dessa koder betyder?
CC-ID 24
CC-ID 35
BMW 120d 2007 e87
Pe
144
Pelleulf
525i Touring -08
Alfa 1600 Gtj-74
Beach Buggy -69
Norton 750 Commando -71
Skulle vilja ha koderna för ECU: MSD 80.0 om du har dessa.
Har en 525i -08 LCI E61
Med vänlig hälsning,
Pelle
MaBlo
Mercedes C180 kombi
Jag har problem med min 728 -99 (E-38). Kod 128. Har du en komplett felkodslista, så vill jag gärna få den skickad till mig. mablo@tele2.se
Tack på förhand. Mats
MaBlo
Pe
144
Pelleulf
525i Touring -08
Alfa 1600 Gtj-74
Beach Buggy -69
Gärna för resten av bilen också :-)
pelleulf@gmail.com
Pelle
Ci
Cidde
Bmw 525i M-sport touring - 06
Kan du maila svaren på mina felkoder till mig.
Bilen är BMW 525i turin m-sport. 2006.
Mail adress: hansson.christer@outlook.com
Felkoder nr 1. 2EF5
2. 2E81
3. 4F8B Gear shift 5-6
4. E6S
Tackar på förhand.
Christer
@emilkringlund
De två betyder troligtvis följande (se nedan).
I samband med dessa så bör även din DSC-lampa ha indikerat att systemet är ur funktion.
CCID 24
DBC Failed
CCID 35
DSC Failed
Ci
Cidde
Hej Patrik,
Jag har frågat dig om mina felkoder annonsen ligger ovanpå ditt senaste svar.
Jag fick inte med alla felkoder då därför skriver jag om min förfrågan.
Du får gärna skicka hela listan till min E- mail.
Bilen är BMW 525i touring m-sport. 2006.
Felkod nr: 1. AoB4
2. B5
3. B6
4. 2EF5
5. 2E81
6. 4F8B
7. E6S ( kan vara EGS )
Tackar på förhand Christer
Matthias
328i GT - 2016
320d - 08
X5 40d - 13
Någon som kan dessa felkoder e90:
A6CA
A6CB
Matthias
Pe
144
Pelleulf
525i Touring -08
Alfa 1600 Gtj-74
Beach Buggy -69
Hej Matthias!
Funkar torkarna till vindrutan?
A6CA och A6CB verkar vara något med styrboxen till vinrutetorkarnas steg 1 & 2.
Googla på koderna och bmw så finns info i trådarna där.
Pelle
