Bränsleförbrukning på 320 SI
Någon som har en 320SI här som kan svara på vad den drar ungefär vid stads/landsvägs körning?
racing-jimpa
320i stcc -04
Lite offtopic kanske men vad är SI för nåt?
De
764
Deimos
320d GT xdrive -16
Verkar vara någon specialutgåva av E90, taget från wiki:
The 320si is a special homologation version, built in order to qualify the car for the FIA World Touring Car Championship (WTCC).[3] It was released in 2006 and limited to 2,600 units. The 320si uses a modified 4 cylinder engine (N45) different from the standard 320i (N46). Modifications include an increased redline to 7,300 rpm, a shortened stroke (by 2 mm), an increased bore (by 1 mm) and a higher compression ratio (11.0:1). The engine is mostly hand built and does not have Valvetronic, decreasing the number of moving parts. Acceleration from 0 to 100 km/h (62 mph) takes 8.1 seconds and acceleration in fourth gear from 80 km/h (50 mph) to 120 km/h (75 mph) takes 7.7 seconds compared with a standard 320i which achieves 9.0 and 9.1 seconds respectively. Fourth gear acceleration is comparable to that of the 325i which achieves the 80 to 120 km/h} sprint in 7.50 seconds.
