Bilstereo Navi Tele Ljud Larm
1.384
Alpine MP3/CD-växlare till BMW orginal stereo
Hittade detta på en amerikansk BMW lista. Låter som ett intressant alternativ till BMWs CD-växlare! /RS2
Alpine CHA-S634 6 Disc CD Changer (Ai-NET)
I installed (finally) my Alpine mp3 changer last night. It works great with the stock head unit.
There is a bit of lag between songs and it's a pain to navigate 400 songs one by one, but other than that it's great to be able to have so much music in the car at once.
Ok first of all, here are the parts you need to install the alpine cd changer into a non-HK non-NAV M3.
To do this with a NAV and/or HK system you will need slightly different parts for the rear panel. You can check with a BMW dealer to find out. The cd changer and it's adaptors should be the same.
Check here for some info: Länk
Parts:
Alpine Changer (CHA-S634)
Alpine Ai-Net to M-Bus adaptor (KCA-130B)
Soundgate BMW/Alpine I-Bus to M-Bus adaptor (ABMW35V2)
BMW E46 2-dr lh liner foldingseat (51 47 8 266 569)
BMW E46 4-dr/2-dr lh quarter brackets (82 11 1 470 436)
The BMW parts came with all the instructions I needed. However, these sites were helpful:
E46 changer install with NAV: Länk
E46 changer install without NAV: Länk
Here are the basics on what you have to do:
- remove the left trunk liner and the little plastic tray underneath
- remove the amplifier
- mount the amp to the new brackets
- mount the brackets to the left back trunk section
- mount the changer
- attach the changer to the KCA-130B connector
- attach the KCA-130B connector to the Soundgate adaptor
- attach the Soundgate adaptor to the BMW pre-wiring for the cd changer
- re-add the new trunk liner
That's it. The only problem I had was a rivet right behind the rear seat. It took me a long time to get that out. The instructions that came with the kit said to remove the rear left side bolsters but that was almost impossible to do. So what I did was remove the rear seat and pull the rear bolster out a bit to get to the rivet. Also, the instructions say to remove the trunk headliner, but I didn't need to do that. Just be careful not to break the plastic latch holding the rear trunk liner in place.
It worked right away no problems. You can only see track and cd numbers, for example CD1-1 so you can't search for songs/albums easily.
Några fler länkar till ovanstående prylar. /RS2
KCA-130B M-Bus to Ai-Net adapter cable
Soundgate BMW to Alpine M-Bus adapter
ariston
523i -06
316i -92 (i Grekland)
Fantastisk information, har precis satt igång hela karusellen med s634 till min e39:a.
Det fanns tydligen (läste detta på en hemsida ngnstans)2 st. olika protokollomvandlare från BMW-bus till Alpine-bus (som klarar av att prata med mp3-växlaren) där den ena var mkt snabbare på att 'bläddra', dock utan att klara av mp3-text (den som klarar av detta borde med bibehållen originalstereo borde få Oscar i programmering). Ska kolla upp vad modellerna hette...
"... If you think things are under control, then you're not driving fast enough..." (Mario Andretti)
Här är ytterligare en länk med installations anvisningar och bilder mm.
Det finns också två M-Bus adapter som har kommit i nya versioner för att passa nyare widescreen navigator mm, Blitzsafe och Soundgate.
/RS2
Fick den installerad ny i samband med leverans av bilen och kan bara tillägga att jag är helnöjd! Bra ljud och funktion.
Fick hjälp av Länk.
ariston
523i -06
tack för tipset, rs2. Tydligen så har det dykt upp en aktör till, enligt tipssidan, Incar developments ltd med sin BMWE46/39-ALP -adapter (Länk. Ska försöka hitta ett ställe i England/Tyskland/Frankrike att beställa allt från så jag minimerar frakten.
Zx
632
ZxD
E46 M3 -03
Jag har en orginal monterad cd växlare, behöver jag dra nya kablar om jag ska byta till den ni skriver om här?
___________________________________
2:an är den förste att förlora guldet.
ZxD: Nej, de behövs inte. Du behöver en ny växlare samt en alpine adapter.
Bitte, benutzen Sie die Suchfunktion.
Bruka sökfunktionen först fråga sen.
BMWCS Syd #05392
Zx
632
ZxD
E46 M3 -03
wendtan Tack!
Letar 540iA Touring 00-
ZxD: www.bilradiohornan.se vet jag har saker i lager till denna ganska coola modifering i min mening.
BMWCS Syd #05392
Zx
632
ZxD
E46 M3 -03
Tack! Ska bli skönt med lite större variation på musiken i bilen! Den tiden man inte njuter av motorljudet ;-)
Den e lite småbuggig när man går över låt nr 100 men annars funkar den helt okej.
BMWCS Syd #05392
