Bilstereo Navi Tele Ljud Larm
867
piouts på hk stärkare i en e46 -04
nån som har shema på hk steget . eller länk till nåt ställe som har
Ca
557
Carl 123
330 cab -01
116 -06
Nedan info är taget från länken Länk som visar rätt mycket om ljudsystemet i e46. Bilderna finns rätt långt ned i texten.
Lycka till!
The notation I used below is:
Pin # xx / Signal
(main wire color) / (wire stripe color)
no connection literally means that there is not a wire in the factory harness at that pin.
Signal name followed by an * are signals that I believe to be correct, the color code is verified with the harness etc, but I did not personally use these signals in the upgrade so I can not claim to have proven the connections out personally. In particular I did not verify the +/- polarity of the factory mid range speakers. The non-* signals lines I am using to run the upgraded system so I am sure they are correct (at least for my car).
The harness connector pin numbers are embossed on the plastic. There are two “halves” to the connector, looking at the female harness connector its pin lay out looks like this:
Grey ½ of connector
Pin # 13 / Tweeter Rear Right door + * Yellow Pin # 21 / Tweeter Rear Right door - *Blue / yellow
Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
Pin # 7 / no connection Pin #15 / no connection
Pin # 6 / no connection Pin #14 / no connection
Pin # 5 / +12v factory amp +12v supply *Red / green
Pin # 4 / Woofer Front Left +Blue / white
Pin # 3 / Woofer Front Left -Blue / brown
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
Black ½ of connector
Pin # 34 / Tweeter Front Left - Yellow / brown Pin # 42 / Mid Front Right door + *Green
Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
Pin # 28 / no connection Pin #36 / no connection
Pin # 27 / no connection Pin #35 / no connection
Pin # 26 / DC ground factory ampBrown
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
Pin # 23 / Woofer Front Right +Blue / Red
Pin # 22 / Woofer Front Right -Blue / Brown
Pins 1-5 and 22-26 are heavier connections that then other pins, these are the ones that feed the woofers and provide power to the factory amp. I did not use the power connections for the factory amp for the ADS amp – the ADS can draw 30A and the factory connector had wire much to small for that type of current draw. Instead I powered the ADS amp directly (with safety fuses etc) from the battery (easy since BMW puts the battery in the trunk).
Carl
