1-Serien
1.289
Demontering av dörrsida
pe
6
perren79
118d 5d -07
Någon som demonterat dörrsidor fram på en 1-serie? Tänkte byta ut högtalarna... Vet inte riktigt hur man får loss allt utan att nåt går sönder...
Ha de!
Ro
36
Robbo
E36 M3 Cabrio SMG -99
Här kommer en instr. på engelska:
To get at the front speakers you need to:
1. Remove the cover on the door handle (the bit that is titanium or gomera black etc..). Once you have the cover off, undo the 2 screws that you can see. They are a star type head screw (not phillips or flat).
2. Using something very thin, carefully remove the screw cover near the door handle. Again once you have the cover off, undo the screw underneath.
3. Start uncliping the door skin from the bottom, but do not unclip it completely.
4. Reach up behind the door skin towards the electric window switch. If you push the switch from underneath, it should pop out easily (I find this easier than levering the window switch out from the top). Undo the electrical connector to the switch.
5. The door handle is connected by a cable to the door release mechanism. Unclip the cable from the door where it terminates near the striker.
6. Finish uncliping the door skin completely.
7. Lastly, undo any remaining electrical connectors.
You should now have the door skin (with the speaker attached) in your hands. Installation of the door skin is simply a reverse of the above steps.
Lycka till.
/R
pe
6
perren79
118d 5d -07
Robbo:
Tack för hjälpen!!
