e-60 service oljebyte nollställning
M.
44
M.JOHAN.
530IA SEDAN -04
Jag undrar om någon vet hur man nollar servicekontrollen vid oljebyte på en e60-04 lyckas inte hitta något här på forumet. tacksam för svar
Fr
1.147
Freude am Fahren
330E xdrive touring -25
från e60.net. se punkt 6
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
M.
44
M.JOHAN.
530IA SEDAN -04
Jag har bytt oljan 250 mil innan det var dags egentligen.Bilen är utrustad med idrive så man kan ju få fram alla olika serviceåtgärderna på skärmen,men det kanske inte går att ställa om innan det är dags enligt bilen.
He
3.464
Hewi
530iM-00 Immolarot II
118D-08 Karmosinröd
Har du provat ovanstående?
Th
65
ThomasE
F21 M135i, -13
F31 330i, -16
Har en e60 530d tillverkad nov 2006.
Ovanstående fungerar inte på min bil. Har BMW ändrat tillvägagångssättet? Finns det någon som vet hur man gör?
pr
259
protos
E60 520I-04
Måste inte intervallet vara uppnått för att nollställa?(larm att det är dags)
Har fungerat för mig för bromsar,microfiler,olja
Th
65
ThomasE
F21 M135i, -13
F31 330i, -16
Har hört att 80% av körsträckanska vara uppnådd för att kunna nollställa via knappen för trippmätaren. I andra fall måste BMW (eller nån annan...) koppla upp bilen till datorn.
Jag besökte BMW nu på morgonen för att nollställa detta. Fick dessvärre inte möjlighet att vara tillräckligt nära för att se hur han gjorde. Han var inte heller speciellt intresserad av att förklara. I princip följde han de instruktioner som beskrivs ovan. Måste vara jag som gör något fel.... Är det någon som har erfarenhet så mottager jag tacksamt mer info i ämnet.
He
4
HenkeLKPG
535D -07 LCI
ThomasE m.fl
Jag bytte olja igår och fipplade med nollställningen nu ikväll. Hade också lite huvudbry innan jag fick till det på min 07:a. I beskrivningen står det om att "nyckeln" ska vara i tändningsläget och då jag har start/stoppknapp så hade jag ingen koll på hur det skulle ske.
Men det funkade till slut och jag gjorde på ett ungefär enligt följande:
Nollade trippmätaren med motorn igång.
Slog sedan av motorn.
Tryckte på startknappen UTAN att ha foten på bromspedalen (= tändningsläge, oljelampor o dyl tänds).
Satte sedan foten på pedalen och tryckte in trippmätarknappen i några sekunder tills "triangeln" syntes.
Släppte knappen och tryckte in den ganska direkt igen och höll den inne tills det dök upp en Oljekanna. (om det är något annat så går det att släppa och trycka knappen tills önskad symbol dyker upp).
Släppte den igen och tryckte tills "Reset?" visade sig.
Släppte och tryckte igen i ett antal sekunder tills kilometrarna ändrades.
Klart.
Mitt dilemma var just tändningen och när man skulle ha foten på bromsen eller inte. Ska väl tillägga att detta gäller en automat, möjligt att det är något annorlunda på en manuell?
Lycka till :)
Th
65
ThomasE
F21 M135i, -13
F31 330i, -16
Efter ha följt HenkeLKPG's råd att som steg 1, sätta in nyckeln och trycka på startknappen utan att hålla nere bromspedal (och koppling, min bil har manuell låda) så fungerar nollställningen av inspektioner utmärkt. Bara att följa instruktionerna ovan.
Många tack :D
La
720
Lasse Eklunda
530xDA Sedan -15
Z4M Coupe -07
523i LCI Sedan -07
Corvette Bigblock -72
Tack Henke.
Kan passa på att tipsa att Biltemas verktyg 20323 passar oljefiltret ( i.a.f. på 523 LCI 2007) 87mm med 16 "sidor".
//Lasse
Titta på det här klippet
sw
460
swe-boy
420D -15
Kanske skulle ändra i texten under mektips att man på manuell måste trycka ner bromsen sedan trycka på "start" så tändningen slås på.
