1.934
Sportluftfilter på 320d?
Som rubriken lyder, Har sökt utan att finna några resultat? Kan man alls ha det? Vart sitter det? Stort ingrepp att byta? Blire någon skillnad ljudmässigt? Finns det en dumpventil på en diesel bil?
Mvh Magnus
En gång bmw, Alltid bmw
amullo
-18 F31 320da x-drive Msport
-10 Ducati Multistrada 1200s
Sportluftfilter ger väl egentligen inga fördelar jämfört med ett vanligt filter på lilla 320D.
Dumpventil på diesel är ingen idé. Ger inget, således helt onödigt att montera även om det gick.
Hittade detta på ett Trubo forum i USA..
11. Blow-off valves or BOV or similar
Since people insist upon asking about these devices, they need to be discussed ... The purpose of a "blow-off valve" or "diverter valve" on a gasoline engine is to give boost pressure someplace to go when the throttle plate is abruptly closed, to prevent operating the compressor in the "surge" regime. Since a diesel engine doesn't have a throttle plate, a gadget like this serves absolutely no purpose and has no business anywhere on a diesel engine. "But I like the cool noise ..." Too bad, this discussion is focused on things that WORK. Even if you manage to find some way to make such a device work, the noise of people "in the know" laughing at you because they realize that it has absolutely no place on your engine will drown out the noise that the device itself makes.
Installation: Impossible. Cannot be made to work even if you insist upon it.
Advantages: None.
Disadvantages: Won't work. People who actually know how a diesel engine works will laugh at you for even considering it.
Cost factor: Too much, all things considered.
Cautions specific to this modification: Won't accomplish anything.
Suggested modifications in parallel: Irrelevant.
"Bang for the Buck": One hundred percent total waste of time and money.
What if I want more? Do something that actually accomplishes something ...
Skall du göra något för ökad effekt så chippa bilen hos en bra chipningsfirma (exemplvis ESS-tuning) eller sätt på en bra dieseltrimbox.
//amullo
Tack för ett bra och komplett svar på mina funderingar.. Har redan en d-chip high end box från dieseltech i bilen så tänkte därav om det gick att få något sportigare ljud? Vad tror ni om sänkningsfjädrar? Bra eller dåligt då det sitter 18" 225/40 fram och 265/35 bak men det är orginalfälgar med et 47 iaf. Fram är den 8tum och bak 8.5. Vad är lämplig sänkning? Vill inte att det ska klatra och ta i överallt.. Lite offtopic men jag är nybörjare på att snygga till bilen samt använda forumet..
Mvh Magnus
