Ny mjukvara till E9x serien är nu släppt V25
Alf_VON_Sil
BMW X4 20d
Jeep Wrangler YJ
"Skogsbesten"
BMW har nu släppt V25 för motorstyrning och navigation till alla E9X bilar. Några av felen lider min bil av, skall bli skönt att få det fixat. Så boka tid för uppdatering nu gubbar.
Här är några grejer som är fixade:
The following software errors were corrected with the release of Progman 25.00.00 (Target data Status E89x-07-03-515).
If there is an incoming telephone call while SVS (Voice Input System) is active it is not possible to accept or reject the call.
A loud humming noise can be heard from the auxiliary fan when the vehicle is idling.
The automatic transmission enters "Failsafe" mode during a 5-4 downshift. EGS fault "AF8D – ratio monitoring 5-4 gearshift plausibility" is stored.
CCC: The programmable diamond MFL button does not work when set to "Next entertainment source" when vehicle is in motion.
CCC: The customer occasionally has poor radio reception after the vehicle was programmed with Progman V23.x or V24.x.
The speedometer and tachometer needles shake when the vehicle is idling.
CCC: Slow response to inputs made when using controller after startup.
CCC: A high frequency whistling noise intermittently can been heard in radio mode
CCC: Navigation system pop-up arrow display missing. Refer to SI B84 61 06.
CCC: CD/CDC track advances after key cycled. Refer to SI B65 32 05.
SDARS (Satellite radio) receiver fault "A537 – Sat aerial short circuit" is stored.
PROCEDURE
For all vehicles, on a customer complaint basis only, refer to the following procedure and warranty information.
Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B, using Progman 25.00.00 ( Target Data Status E89x-07-03-515) or higher.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Pi
68
Pileman
330ex g21 m-paket -22 ny leasing
Hej Alf!
Du skulle inte kunna förklara på svenska, jag är inte så bra på främmande språk tack på för hand!
Kör försiktigt så att du inte skadar någon! (eller din BMW)
Mo
47
Moffe
325xi Touring -07
Är det någon som vet om det finns något sätt att kolla vilken version på mjukvaran man har. Misstänker att det finns någon knappkombination att trycka?
Mo
47
Moffe
325xi Touring -07
