Hastigheten visas digitalt?
Ri
461
Rille330
330i Touring -02
M3'an i filmen nedan visar hastigheten digitalt (istället för antal mil).
Hur aktiverar man denna funktion på E46?
"Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Du ser her at det er punkt 7.3 som er hastighetsmetare og oppe ser du hvordan du kommer inn på OBC i bilen din"
Hittade den från ett tidigare inlägg, Länk
Ri
461
Rille330
330i Touring -02
TACK! Vill bara bekräfta att det fungerar. Riktigt skoj att kunna se t.ex
RPM och KMH digitalt i displayen. Lite synd bara att man måste trycka en
kombination av 20-30 tryckningar innan det ens dyker upp?
När ändå informationen finns där så lättillgänglig så tycker man att vi
kunde ha fått det som enkla alternativ i OBC'n? Thänk jo BMW...
Bm
101
BmwMClubsport
BMW 520d M-sport -10
Kanske länge sen någon skrev här men detta verkade kul.
Är det lika enkelt att återfå miltalen i displayen, alltså att man gör likadant fast väljer tex. nr 21 som återställer OBC'n?
När man väl har ändrat, måste man göra detta varje gång man startar bilen eller förblir det alltid det sista valda alternativet man gjort?
Tack på förhand
Det återställs varje gång bilen stängs av. Du har just blivit mästare på att dra upp gamla trådar :)
Vorsprung durch freude am fahren
32ProPro-medlem
2.477
325cabrio
330eX touring -22
330iA cabrio -03
Utan att vet så gissar jag att setting betyder inställningar och inte lagrade värden. Du återställer alltså valda inställningar som att visa mätarställning istället för miltal men du nollställer inte mätarställning. Mätarställning är ju ett värde och inte en inställning/setting.
/Patrik, 325i cabrio -94, 325i touring -02, BMW CS 4096
Fungerar detta på alla bmw E46 med färddator eller bara på m3?
