need help with radiator trouble
dr
6
drooby
320i touring-02
BMW 330i 2002
I think i may have filled the radiator with too much coolant. Now the warning light comes on very often, so i check the fluid levels in the radiator and it needs filled everytime. i cant find any place where it can get out, well not obvious leaks anyways. Is there an overflow or have i damaged the system beyond repair?, i dont know. Please help a hopeless scottish guy who loves his BMW almost as much as his girlfriend.
Tack
Ni
39
Nick_name
530dA Touring (E61)-06
Do you see any leaks after having parked the car? If there is a leak you should notice it by fluid on the ground. If there in fact is a leak you can by some sort of cement at most petrol stations or try some baking soda!
