Fel på färddatorn (L\Mil)
WB_M5
E30 325im -88
Ska kolla på en 325a som snittförbrukningen i färddatorn (lilla) inte fungerar på.
Vad kan det breo på? Hur fungerar den? vart mäter den osv?
Mvh Erik
ma
597
magican
E36 328 Coupe
Lilla färddatorn väl ingen bränsleförbrukningsmätare? Är ju bara största 18 knappars som har den vad jag vet.
Men visst.. här haru.
The following is for newer OBC found in E36 cars for example:
To determine if your OBC is eligible .. press 1000 and 10 together.
you should see TEST NO . -- or something like that.
Now, some of the functions are locked out -- I do NOT recommend messing with them and you do so at your own risk -- that said ...
To unlock all functions .. press 1000 and 10 and at the TEST prompt enter 19 using the keys .. press SET/RES .. you should see LOCK:ON or something similar ... press the DATE key .. (today you'd see 08.20) and add the two numbers (day and month) together (today 28)
Now enter the number you just calculated (28) and press SET/RES. TADA .. you have unlocked the secret functions ...
To lock them back up .. press 1000 and 10 then enter 19, SET/RES now press SET/RES again .. it should show .. LOCK:ON again
In general when I show a test enter it by pressing 1000 and 10 together then enter the number of the test with the numeric keys and press SET/RES to actually execute the test ...
Test numbers for E36 OBC (Note: Joe this should also work for your 535!) Test no. Description
1 Display Test .. all LCDs and LEDs activate
2 Current Consumption in l/100km
3 Current Consumption in l/hour
4 Average Consumption (used to calc. Range)
5 Current Range
6 Not used ..
7 Average Fuel in Tank (l)
8 Current Speed (km/h)
9 System Voltage at terminal R
10 Country/Language
11 Units/ AM.PM
12 Average Speed (km/h) for calc. ETA
13 ETA
14 Date of software/mask of OBC
15 Production Diagnosis ()
16 Production Diagnosis ()
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous v. intermittent)
19 LOCK/UNLOCK all functions
20 Correction Factor for OBC Fuel Consumption (SEE BELOW!)
21 Reset all defect codes, date and time ... activate by pressing SET/RES
Note on test #20:
The factor is used to correct the OBC Avg Fuel Consumption figure to reality. If your OBC is off a bit: fill UP totally, run tank down and refill; then calculate your Actual MPG. Now enter test 20 to get the old Correction Factor.
NEW CF= OLD CF *(OBC MPG/Actual MPG)
Enter the NEW CF using the numeric keys and hit SET/RES to store. PLEASE record your OLD CF so that IF you screw up you can always go back to what it was.
WB_M5
E30 325im -88
Jag ber så mycket om ursäkt, jag missförstod den förre ägaren, det är natruligtvis ekonomi mätaern som inte fungerar, den hoppas från min till max iblan, finns lixom inget mellan läge.
Mvh Erik
Cr
1.381
Cruser
325i -92
328i-97 touring
beror bara på hur mkt du trycker ner gasen, tror jag...testa såhär
kör i typ 70,(spelar ingen roll)
1.släpp gasen med växel i, (motorbromsa) då skall mätaren ligga på noll.
2.trampa ner kopplingen i fart, då skall den ligga på ca:0,4.
dettta har ja fått sagt till mig några gånger....
WB_M5
E30 325im -88
Jo jag vet. men det gör den inte.. om jag kör i 70 med halvgas så visar den ingenting, sen när jag gasar upp den mot ca 3500varv så drar mätare upp i max och håller sig där till jag släpper, då grå den tillbaka till 0 igen..
Mvh Erik
Cr
1.381
Cruser
325i -92
328i-97 touring
då är den sönder
WB_M5
E30 325im -88
hehe jo det vet jag, men vad är det som kan vara sönder??
Mvh Erik
WB_M5
E30 325im -88
Nu har jag haft bilen lite mer och har kollat lite på vad det kan vara med ekonomimätaren, men jag förstår inte vad det kan vara.. Kan det vara dom så kallade si batterierna? kan det vara så att det bara är ekonomimätare som beter sig konstigt?
Det är så att när jag kör normalt och står på tomgång så står mätaren på 0. men om jag trycker på fult om kommer upp över 3an, sen håller den sig där tills jag släpper av. den har lixom inget mellan läge..
Har försökt hitta info på forumet men inte hittat något. alla säger olika..
Mvh Erik
