528 I Touring Höger framdörr i baklås.
Ja
1
Jan Björnberg
BMW 528E Touring
Det går inte att öppna innifrån med handtaget ej heller att dra upp knappen, hur gör man????
Inte jättekul fel det, läs mer här: Länk och här: Länk
Tips:
Sökfunktionen den ger massor av träffar.
PeterB
hasso
520i-1989 Alpinevit II
BMWCS 04247
Monark 50S 69-71
Yamaha xs400 12E Seca -82
Honda CB 650-82
Yamaha XJ750 Seca -82
Captur Intens II-19
Ett tipps från BMW i USA.
Hi,
Problem solved. The BMW guys gave me a tip that there is a possibility to unlock the door without any damagesand it takes about 30 minutes. So I made an research and found solution.
1. You have to remowe upper end od door panel trim. It is not difficoult. Just unscrew one screw and move panel up (use a lot of force otherwise it will not move). Then push panel to the inside of the car.
2. When uppre part of door trim panel is remowed you will see 5 wires. A black one, white, brown and two blue ones. Brown and blue are wrapped together. DON'T TOUCH them they are for side air bag.
3. Find another blue and white. Remove a bit of insulation and attach 2 wires (about 1 meter long) to them.
3. Remowe glove box and you will see the computer that controls locks and door. Find big black plug. Connect blue wire to a blue wire in that blug and wgite to white.
4. Now you can open the door with remote control.
5. In my particular case the problem was with lack of contact in the plug between the door and the car body. I just unpluged, cleaned it and everything is just fine.
///MVH Hasso
