e34, 530i V8, oil change... but to what
br
28
brevis
530i V8 Touring -95
Got my 530i V8 this tuesday and I want to change the oil right away :)
Question is, what would you recommend?
Car has driven 366tkm and purs like a kitten.
Manual says 15W40 oil.
What would you put on it :) semi or full synthetic?
I would use a full synthetic oil of high quality f ex Mobil 1 or Castrol. To be on the safe side do two oilchanges in a row to flush out residual particles from the engine .I would use a cheaper oil at the first change and then put in the good stuff. If you want to use semi oil Motul have a good one .
Good luck !
halvgute
530i Touring-93
Va fan,skriv på dansk..dom flesta begriper det,OK,Hi brevis! Im using Mobil 1, 5,40 full synthetic oil in my engine and i am happy with that oil,only use well known oilbrands!
¤¤¤¤¤¤¤¤¤IRON MAIDEN¤¤¤¤¤¤¤¤¤
MuProPro-medlem
7.993
Mugge
F20 - 116d -16
991 - 911 Carrera 4 - 13
I doesn't matter what brand you use, the important part is the API / ACEA clasification. And yes I would recomend you to use a fully syntethic motoroil.
I would recomend an oil that excedes the demands for API SL/CF or ACEA A3.
Vagnparken: Länk
