E34 Touring, rear lights, all red or red/black
br
28
brevis
530i V8 Touring -95
Hope its ok to do this in english, im from Denmark so cant type swedish very well but understanding is fine :)
Im about to buy a E34 Touring. The rear lights are the usual dull red/yellow.
I saw a 540 touring equipped with all red lights and have seen another car with red/black lights.
HAvent had any luck in finding these styles of rear lights.
Is it possible any of you know where to get hold of them? :)
Dandelue
540iA Touring -94
I tinted my rear lights all red with spray.. I dont think you can but them all red.
Check out my pictures below...
DANNE
Min bil:
ac
16
acalson
525i Touring 93:a
Tycker du ska köpa vita blinkersglas och byta själv, ser klart fräschast ut tycker jag.
DIY for red/whites: Länk ( btw: www.touringklubben.com rules!!)
Sharifhan; Var glad att du inte bor i Tyskland, förre ägaren till min gröna 540i/6 hade svarta bakljus från Hella "godkända" men inga extra reflexer, han blev stoppad av Polizei, resultat? €60 i böter samt 2 eller var det 3 prickar i körkortsregistret i Flensburg = det kan alltid vara värre.
Mvh Stephan
br
28
brevis
530i V8 Touring -95
Yep, did try to search, but no luck with the red/red or red/black lights.
Might have to be red/white and then color the whites either black or red.
Thanks for the info on where to get them thou, was ace! :)
br
28
brevis
530i V8 Touring -95
Oh btw Dandelue, your red taillights, are they the normal yellow ones sprayed red or the white ones?
ac
16
acalson
525i Touring 93:a
Jag tror dom är sprayade men är inte helt säker.
Dandelue
540iA Touring -94
Brevis,
My tail lights are the standard red/yellow which are sprayed red/red. You cant tell the difference between the origional red and the sprayed red, so I'm very pleased...
DANNE
Min bil:
br
28
brevis
530i V8 Touring -95
Did you spray both the red and yellow with the red paint to get the same "shine" or just the yellow part :)
br
28
brevis
530i V8 Touring -95
By the way, does E39 wheels fit onto the E34, ET measurements are the same, but what about nut distance.
E34 is 5 x 120, what is E39? :)
Dandelue...vad var det för spray du sprayade med?? måste det vara någon speciell eller??
Dandelue
540iA Touring -94
I only sprayed the yellow part. and not the red. The spray can be bought at most any parts shop. It is a spray for tinting lights and it is not too expensive. In sweden you can buy it in any Mekonomen...
Good luck!
DANNE
Min bil:
Dandelue
540iA Touring -94
I forgot to name that you spray it in layers till it matches the color you want... There is black tint as well if that is what you perfer.
DANNE
Min bil:
brevis; E39 har samma fälgar som E34 förutom att du behöver en centreringsring eftersom navhålet är större.
Mvh Stephan
